Does the fuel gauge switch tanks when the selector valve switches? Both tanks worked on the gauge until I switched it today from the rear to front tank. My fuse blew at the same time and now it's stuck on the front tank. I'm guessing that the valve is stuck now and needs to be replaced. I just want to be certain that the fuel levels moved by the switch or the valves electronics. Also, I found this. I'm wondering if it's going to work with the stock plug.
