1999 e350 7.3 powerstroke van. So the truck has a funky issue. At partial throttle (id say 1/3 throttle) it has this weird bog. The truck makes a loud moaning/gurgling sound and loses power. Once you put the pedal to the floor the truck snaps out of it and runs perfect. If i drive around flat footing it all day id never notice the problem, but thats a little excessive haha. Its cold here in new york and the problem is definitely worse while the motors warming up. Its really annoying when cruising at 50-55 because it will get caught in that bog and I’ll have to constantly floor it and then let it coast.
Im running antigel in the fuel
new fuel filter/water seperator
new air filters
does it need this feature or is it something guys delete? I have to take the cowl off and look at it
The actuator has some O-rings in it that will leak over time and many guys delete it. Deleting it is a split camp, some advocate for it, others against it because it does help warm a cold engine in the colder northern temps. And some use it as for engine brake.
Wiring it open as a test wont hurt anything though. Even some in cold areas delete it because it will constantly close and open while going down
the road.
Gotta try it and see if it helps first, this is just a guess at the symptoms.
