Sponsored by: Real Truck
Transmission troubles
Old Jan 15, 2019 | 07:05 PM
Gametrap's Avatar
Gametrap
Ok guys I'm getting a p0755 code I can erase the code but it comes back as soon as the truck is started
the truck is a 2004 f250 5.4l gas with 256000 where should I start tracking the problem
Old Jan 15, 2019 | 09:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That code indicates you have a stuck shift solenoid B. I'd start with shift solenoid B.
Old Jan 15, 2019 | 09:23 PM
projectSHO89's Avatar
projectSHO89
I'd start with checking the circuit for shift solenoid B.
The WSM defines the condition as:
SSB circuit failure.SSB circuit fails to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during KOEO.
james.odum
May 22, 2016 03:09 PM
Greek 350
Mar 15, 2012 08:02 PM
tarditim
Oct 12, 2011 03:29 PM
twall_SD250
Mar 20, 2010 09:40 PM
steverowe
Mar 5, 2004 03:56 PM
