1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Super bright replcement reverse bulbs
Old 01-13-2019, 07:57 PM
st8yd's Avatar
st8yd
st8yd is offline
I don't want to get into wiring new lights right now, just want some super bright LED replacement reverse bulbs. I just put a 10" led bar on my tractor the other day and was amazed at how small the wire is.
So surely there is a reverse bulb out that should substantially out do the stock bulbs and not be too much for the system.
Has anyone tried any?
Thanks
Old 01-13-2019, 08:11 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
I have been using the lastfit led lights, decent price and full aluminum with cree diodes.
Old 01-13-2019, 08:19 PM
st8yd's Avatar
st8yd
st8yd is offline
How much brighter are they than stock?
Old 01-13-2019, 09:38 PM
marksman76's Avatar
marksman76
marksman76 is offline
I bought some from JC Whitney years ago.
Not too impressed, but.....
Old 01-13-2019, 10:14 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Have you gone to Superbrightleds.com?
Old 01-14-2019, 06:37 AM
st8yd's Avatar
st8yd
st8yd is offline
I see they have a couple maybe, one at 500 and one at 550 lumens.
Also found this Super Bright White 6000K LED Reverse Lights 921 3156 7440
but no lumens rating however it does state that the approximate light output equivalent ~80 watt output equivalent vs. 23 to 28 watts for stock bulb.
Just hoping maybe someone has experience with some.
Thanks
=left
Old 01-14-2019, 07:32 AM
seville009's Avatar
seville009
seville009 is offline
I put ibrightstar super brite bulbs in my reverse lights last year. They are great, even when plowing.
Old 01-14-2019, 11:42 AM
ford390gashog
Very bright, so far they are the only ones that have lasted 2 years without burning out or overheating. https://www.lasfit.com available on Ebay and Amazon
Old 01-14-2019, 02:53 PM
Jason Cook's Avatar
Jason Cook
Jason Cook is offline
Yes. The super led light dot com is the best place to get any led light for everything you have. They are the brightness and the cheapness. The best bang for your buck!
Old 01-14-2019, 03:35 PM
powersrp's Avatar
powersrp
powersrp is offline
Thumbs up Led bulbs
amazon is a good place to shop also, my truck additions, beamtech h13 (4) for headlights, aux beam t20 7440 bulbs for reverse lights, alla lighting h10 9145 for fog lights, pleased with all bulbs, Hugh difference for headlights and reverse lights. Adjust headlights 1.5 turns cw and you ll be very close.
Old 01-14-2019, 04:08 PM
Mitchoklahoma's Avatar
Mitchoklahoma
Mitchoklahoma is offline
HID Kit Pros . com
for my 2011 F 250 I bought item # 235023 it was a pair of Reverse lights. $39.95 They are Very Very Bright. for a direct replacement. since it is only 1 bulb on each side don't expect it to be like a light bar, but 100 times better than stock.
https://hidkitpros.com/search-results-2/?q=235023
I guess after looking at the picture there are actually 6 LEDs per bulb. 1 on each side and two facing straight back. 450 Lumens. I bought the Pure White, installed them myself (its just a direct plug in so nothing difficult) have had them in since OCT 2016 and no problems.
Old 01-14-2019, 04:10 PM
Mitchoklahoma
Also if anyone has an 11-16, I changed every bulb on my truck to LED. inside and out. so if anyone wants to know the parts number please don't hesitate to ask.
Old 01-26-2019, 05:24 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
BROWN DOG KTM is offline
Originally Posted by Mitchoklahoma
Also if anyone has an 11-16, I changed every bulb on my truck to LED. inside and out ...
Did you use 9005 LED Bulbs in your 11-16 Fogs ?
Old 01-26-2019, 07:56 AM
Mitchoklahoma
Rough Country
I actually put a Ranchhand full bumper replacement on and replaced Fogs with Rough Country Cube lights
Old 01-26-2019, 09:12 AM
BROWN DOG KTM
I bet used take off OEM Stock Frt & Rear Bumpers are PLENTIFUL out in OK & TX
jimzpsd
2017+ Super Duty
26
01-25-2018 06:36 AM
Nimrod
2017+ Super Duty
33
01-28-2017 04:44 PM
Supercab
6.4L Power Stroke Diesel
05-12-2015 10:17 AM
Big.blue0586
01-16-2013 07:32 AM
powrstrkn'
23
02-08-2006 09:40 PM
Quick Reply: Super bright replcement reverse bulbs
