Super bright replcement reverse bulbs
I don't want to get into wiring new lights right now, just want some super bright LED replacement reverse bulbs. I just put a 10" led bar on my tractor the other day and was amazed at how small the wire is.
So surely there is a reverse bulb out that should substantially out do the stock bulbs and not be too much for the system. Has anyone tried any? Thanks |
I have been using the lastfit led lights, decent price and full aluminum with cree diodes.
How much brighter are they than stock?
I bought some from JC Whitney years ago.
Not too impressed, but..... |
Have you gone to Superbrightleds.com? |
Originally Posted by Colorado350
(Post 18416706)
Have you gone to Superbrightleds.com? Also found this Super Bright White 6000K LED Reverse Lights 921 3156 7440 but no lumens rating however it does state that the approximate light output equivalent ~80 watt output equivalent vs. 23 to 28 watts for stock bulb. Just hoping maybe someone has experience with some. Thanks=left |
I put ibrightstar super brite bulbs in my reverse lights last year. They are great, even when plowing. |
Originally Posted by st8yd
(Post 18416435)
Very bright, so far they are the only ones that have lasted 2 years without burning out or overheating. https://www.lasfit.com available on Ebay and Amazon |
Yes. The super led light dot com is the best place to get any led light for everything you have. They are the brightness and the cheapness. The best bang for your buck!
Led bulbs
amazon is a good place to shop also, my truck additions, beamtech h13 (4) for headlights, aux beam t20 7440 bulbs for reverse lights, alla lighting h10 9145 for fog lights, pleased with all bulbs, Hugh difference for headlights and reverse lights. Adjust headlights 1.5 turns cw and you ll be very close. |
HID Kit Pros . com
for my 2011 F 250 I bought item # 235023 it was a pair of Reverse lights. $39.95 They are Very Very Bright. for a direct replacement. since it is only 1 bulb on each side don't expect it to be like a light bar, but 100 times better than stock. https://hidkitpros.com/search-results-2/?q=235023 I guess after looking at the picture there are actually 6 LEDs per bulb. 1 on each side and two facing straight back. 450 Lumens. I bought the Pure White, installed them myself (its just a direct plug in so nothing difficult) have had them in since OCT 2016 and no problems. |
Also if anyone has an 11-16, I changed every bulb on my truck to LED. inside and out. so if anyone wants to know the parts number please don't hesitate to ask.
Originally Posted by Mitchoklahoma
(Post 18418152)
Also if anyone has an 11-16, I changed every bulb on my truck to LED. inside and out ...
Rough Country
I actually put a Ranchhand full bumper replacement on and replaced Fogs with Rough Country Cube lights |
I bet used take off OEM Stock Frt & Rear Bumpers are PLENTIFUL out in OK & TX :-X04 |
