2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Odd DTCs
Old Jan 13, 2019 | 05:00 PM
scottb37's Avatar
scottb37
Odd DTCs
Hey Yall, I had a friend do a scan on my 2010 King Ranch yesterday and came up with some odd codes:
B2324 mirror Driver vertical feedback potentiometer
B2316 Passenger Mirror vertical feedback potentiometer
B2321 Passenger Mirror horizontal feedback
B2498 Headlamp switch multiple signals Input active
I do have a shop manual on the way from Evilbay, but can a technician out there tell me what these mean? I believe the mirrors still adjust and the headlights do come on.
Thanks, Scott
Old Jan 13, 2019 | 10:44 PM
13expedition's Avatar
13expedition
Those codes make me wonder if you either A) have a voltage / Amperage problem B) grounding issue. I'd start by looking at all the grounds related to those items as well as the battery area. I'd also check my battery over well.
That is where I would start. When did those codes occur and how many times have they occurred? when was the last occurrence?
Old Jan 14, 2019 | 06:41 AM
projectSHO89's Avatar
projectSHO89
If all accessories function normally, I'd start by ignoring those codes.
Old Jan 14, 2019 | 09:13 AM
alloro's Avatar
alloro
Those first 3 codes are for memory mirrors only. The potentiometers tell the system where the mirrors are positioned. Getting those codes tells you the memory module cannot read the potentiometers. The headlight code could just be one that was set for whatever reason and once cleared won't come back.
Old Jan 14, 2019 | 07:57 PM
scottb37's Avatar
scottb37
I am not sure when these codes first came up as I just bought the Expy 3 months ago.
I did ask the mechanic to clear them, as long as everything works I wont worry about it.
Thanks to everyone for the responce, I learn a little more everyday.
Thanks, Scott
SuperTrooper641
2015 - 2020 F150
Mar 30, 2025 03:24 PM
PD Rig
Nov 7, 2018 01:28 PM
cullenkyla
2015 - 2020 F150
Jul 3, 2017 06:44 PM
Wingdreamer
2009 - 2014 F150
Dec 15, 2014 09:37 AM
JSolve
Feb 25, 2013 07:46 AM
