HPOP Replacement No Start
Old Jan 12, 2019 | 02:19 PM
robjs111's Avatar
robjs111
Just replaced hpop on my 2001 7.3 and no start.
Gear drive bolt set at 95 ft lbs
hpop res is full
Diesel fuel has been in tank for over a year, could fuel be an issue with no start?
Thanks.
Old Jan 12, 2019 | 02:26 PM
robjs111's Avatar
robjs111
Also I did start to crank motor with no oil in res. Filled with 1 qt now but could there be a lot of air is lines?
Old Jan 12, 2019 | 03:35 PM
PrescottIce's Avatar
PrescottIce
Seems I recall I had to crank mine about 3-4 times for 20-30 seconds each time resting for about the same amount of time in between attempts before it fired, then one more time before it ran. But I had oil in my HPOP to start with.
Have you double-checked all your sensor connections?
Old Jan 12, 2019 | 03:49 PM
00t444e's Avatar
00t444e
Any time you open the HPO system it takes a lot of cranking to bleed it out so it will start.
Old Jan 14, 2019 | 08:38 AM
timmyboy76's Avatar
timmyboy76
If u tried turning it over with no oil in the hpop res, it just became a small airpump. After each 15sec interval with 1min of starter cooldown, id recheck res and fill accordingly
Old Jan 14, 2019 | 01:03 PM
GEugeneS's Avatar
GEugeneS
Sometimes it's dumb "little" things like I put the IPR external sensor (slides over the IPR rod and is secured by the tin nut) on backwards. Reversed it and it started immediately.
Old Jun 7, 2020 | 06:13 PM
Lance Kohler's Avatar
Lance Kohler
temp sensor wires on the egr system right below a coolant line on a friends 6.0litre was a tough one, hose had worn right thru the casing in the wire it was really hard to find so checking all sensor plugs for frayed wires is a great idea. after i rebuilt my 7.3 it took quite a lot of revolutions to prime the system enough to make it fire back up, just make sure you have patience and don’t overheat your starter motorcraft starters are like 700$
Old Jun 8, 2020 | 03:13 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Lance, dude! I appreciate your desire to help. But save your good insights on a recent thread where someone needs help. Not something a year old where the answer is done.
Plus 6.0 tech is mostly not applicable to 7.3s, HEUI injectors are common but not much else.
Stay around! We want helpful folks around here. This is a community of Ford diesel fans of the 7.3 variety, but anybody who wants to contribute is welcome. It's a Sunday potluck so add something and take something.
Old Jun 8, 2020 | 08:00 AM
Lance Kohler
😂 lol thanks for the heads up i didn’t even notice the date on the post.
caveman44
Oct 2, 2021 09:23 PM
WinterBorn
Jul 31, 2018 09:57 AM
bubba_3711
21
Dec 28, 2013 06:59 PM
FallstonYJ
20
Dec 19, 2010 10:37 PM
hosoria
Apr 21, 2009 04:30 PM
