T98 with PTO
Old 01-10-2019, 05:18 PM
Aaron81's Avatar
Aaron81
Aaron81 is offline
T98 with PTO
Just curious if there is any interest in a borg Warner T98 trans with the factory PTO output gear box attached to it. It is out of a 1954 F350 that had a dump bed.
I have a non PTO T98 already; don’t need a PTO on a stake truck I am doing, and debating which one to keep/use/sell.
if it isn’t worth much I might toss in the PTO unit Incase I ever wanted to use it in some fashion.
Old 04-12-2019, 07:14 PM
lkc2273's Avatar
lkc2273
lkc2273 is offline
t98 pto
Hiya- Still got it? I've been looking like crazy for a PTO for my T98 on 1953 f600.
PM Me if so.
Thanks!
Ian c.
Old 04-13-2019, 05:14 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Ford never offered a PTO, it's aftermarket and was either dealer or owner installed.
Old 04-13-2019, 05:20 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Is it just an in-and-out or does it have forward-neutral-reverse?
Old 04-13-2019, 05:22 PM
Aaron81's Avatar
Aaron81
Aaron81 is offline
in and out only.
Old 04-13-2019, 05:24 PM
Aaron81's Avatar
Aaron81
Aaron81 is offline
interesting! So all the trucks that had dump beds, were express trucks, and someone added the bed and hydraulics?
Old 04-13-2019, 05:28 PM
Mixer man's Avatar
Mixer man
Exactly. Ford never offered a dump bed on anything.
Old 04-13-2019, 05:29 PM
Aaron81's Avatar
Aaron81
Aaron81 is offline
makes sense.
Old 04-13-2019, 05:31 PM
Mixer man's Avatar
Mixer man
in and out only.
Dump bed only then, not for winch or power transmission. Power up, gravity down.
Old 04-13-2019, 06:00 PM
Aaron81's Avatar
Aaron81
Aaron81 is offline
it is a single gear that pulls into the counter shaft gear.
Old 04-14-2019, 02:07 PM
fish pond's Avatar
fish pond
fish pond is offline
gravity or power down would depend on the valving and cylinder type wouldn't it?
Greg
Old 04-14-2019, 03:34 PM
Aaron81's Avatar
Aaron81
Aaron81 is offline
Greg
Greg,
your correct. The only way for the PTO to spin backwards is if they ever made one with a "counter gear". It would need 3 gears in it. 1 gear used for forward and 2 gears used for backwards. Next is, if they make a pump that allows reverse rotation?
Every PTO setup of this age I have ever worked on has been 1 direction only, with a gravity return to the oil reservoir.
Old 04-14-2019, 06:25 PM
Mixer man's Avatar
Mixer man
Greg
True. Much simpler, cheaper, and faster for gravity down. Gravity valving simply returns oil straight back to the reservoir.
Greg,
your correct. The only way for the PTO to spin backwards is if they ever made one with a "counter gear". It would need 3 gears in it. 1 gear used for forward and 2 gears used for backwards. Next is, if they make a pump that allows reverse rotation.
Tulsa, Braden, and Gar-Wood made F-N-R and multi-speed PTO's. They were primarily used for winches and transit mixers. A lot of Braden winches were used on military vehicles.
Old 10-22-2019, 07:14 PM
Ray Hogge's Avatar
Ray Hogge
Ray Hogge is offline
Is this available?
[/QUOTE]
Old 10-24-2019, 10:44 AM
Aaron81's Avatar
Aaron81
Aaron81 is offline
[/QUOTE]
sorry sold it about 6 months ago.
mybrownie
39
12-05-2019 07:12 PM
chaney71
Large Truck
06-28-2012 08:35 AM
tnfarmer67
09-05-2010 02:56 PM
46autocar
06-08-2010 11:42 PM
Quick Reply: T98 with PTO
