np 435 pto
Old Sep 5, 2010 | 01:07 PM
tnfarmer67's Avatar
tnfarmer67
np 435 pto
i have a 1966 ford f350 flat bed with a np435 trans. , i am mounting a pto winch in the bed . does the pto have to be shimmed on the trans for clearance issues or do i put the gasket on and bolt up the pto. i surly don't want to tear anything up!!!!!!!. i learned to install studs because bolt won't work.
Old Sep 5, 2010 | 02:56 PM
Flintknapper's Avatar
Flintknapper
Don't know about the 435 but every PTO I've installed on early model bronco's (Dana 20 T-cases) had to be shimmed to get it correct.
You could probably get away with being a little "loose" (too shallow a gear mesh) though it would compromise the strength, but you definitely don't want to be too "tight" (too deep a mesh).
49fordv8f4
Jun 15, 2017 04:48 PM
hail destroyer
Sep 27, 2016 09:36 PM
William Cabot Boyd
Large Truck
Aug 28, 2016 11:32 PM
Bob Lowes
Mar 24, 2016 03:08 PM
packratF350
Feb 7, 2012 08:18 AM
