Low Engine Temp
Old Jan 14, 2019 | 10:01 PM
  #31
Killer79's Avatar
Killer79
I can take the cover off the heater core and look for leaks. The blend door is sealing completely as I vacuumed and zip tied the door shut. When the cover is off the heater core I get plenty of heat but as soon as the cover goes on it's cold.
Old Jan 15, 2019 | 12:10 PM
  #32
Killer79's Avatar
Killer79
I'm going back to college tomorrow and can't work on the truck down there. So I guess I will try to figure it out next winter. Thanks for all the help guys!
Old Jan 15, 2019 | 01:07 PM
  #33
My4Fordtrucks's Avatar
My4Fordtrucks
The temp blend door on my ‘94 Bronco was controlled by a cable so I’m not sure what you vacuumed and zip tied shut. Also are you sure you went to hot and not cold and the door stopped against the heater box and not something in the way?
Old Jan 15, 2019 | 11:24 PM
  #34
TexasGuy001's Avatar
TexasGuy001
Almost all of these trucks I have seen read relatively low on the temp gauge when warmed up. Use an IR thermometer and check the T stat housing and hose etc to see what the temp really is. How cold is the outside temp there?
Jose A.
Aerostar
Sep 22, 2012 09:57 AM
So-Cal Sancho
Jul 11, 2009 01:41 PM
MisterCMK
Dec 17, 2003 02:07 AM
tombob
1978 - 1996 Big Bronco
Dec 2, 2002 12:14 PM
