Thermostat
Old Oct 23, 2003 | 12:00 PM
MisterCMK's Avatar
MisterCMK
Thermostat
I am gonna be replacing my thermostat pretty soon, and there are two different options. The first is a high temp. It opens at about 192 degrees. The second is a medium which opens at 180. What are the pros and cons over each one? Thanks
Old Oct 23, 2003 | 12:03 PM
Bob Ayers's Avatar
Bob Ayers
Stay with the OEM Motorcraft 192 thermostat. The Motorcraft
seems to keep a more constant temperature, and will last longer
than 3rd party thermostats......
Old Oct 23, 2003 | 04:07 PM
aerocolorado's Avatar
aerocolorado
Second to Mr Ayer's comment. While running cooler in summer may not be a bad concept, the engine may not warm sufficiently in the winter months. Thus, the various engine temp sensors keep the engine running overly rich, spoiling your mileage among other evils.
Old Nov 16, 2003 | 05:47 PM
BRI-GUY74's Avatar
BRI-GUY74
If you want heat use the 192 otherwise you dont get s*** for heat....
Old Dec 15, 2003 | 04:00 PM
CougarJohn's Avatar
CougarJohn
I have an old 240 and a pair of 302's. have traditionally used a 180 thermostat year around. I am in mid CA, winter lows about 32, summer highs 95. All engines are sound.
Will a higher thermostat help with engine wear? What temperature should I get? Does the Ford dealer have the stuff or am I in aftermarket?
Thanks, guys
Old Dec 15, 2003 | 05:35 PM
351 power's Avatar
351 power
I had tried the cooler thermostat in my truck. It works better with 195 degrees; less condensation under the oil cap for my driving. Mostly my driving is short trips.
Old Dec 17, 2003 | 02:07 AM
rlh's Avatar
rlh
I use MotoRad FailSafe that stays open if it malfunctions. I go with the 192 in my Bronco 302.
JaySVX
Mar 7, 2013 11:24 AM
jbyrd
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 16, 2006 11:07 PM
ejfitco
Mar 16, 2005 11:18 AM
parkway
Feb 20, 2005 08:52 PM
Avanti
Jun 9, 2004 10:21 AM
