PCM Removal
Old Jan 8, 2019 | 12:53 PM
fluidp's Avatar
fluidp
PCM Removal
Hi All, Sorry for probly a dumb ??, but is there a easy way to remove the PCM.. I did it like ten years ago and I kinda remember having to remove the park brake peddle and it was a real pain to access.
Reason for removing is I did a engine swap a couple months ago, Truck had a 95 PSD and I installed a 97 PSD. Truck still has the PCM from the 95 and it runs ok, but I have a couple small power issues. I do have the PCM from the 97 motor and want to swap and see if that corrects my issues Thanks In Advance...
Old Jan 8, 2019 | 02:26 PM
fordpride's Avatar
fordpride
You have to pull the driver side inner fender down in order to get the pcm out. No need to pull the e-brake assembly.
Old Jan 8, 2019 | 02:42 PM
knottyrope's Avatar
knottyrope
Old Jan 8, 2019 | 04:28 PM
fluidp's Avatar
fluidp
Thanks Gents
Old Jan 9, 2019 | 10:32 AM
dclack's Avatar
dclack
Unless you have a chip in it; then you may need to pull it to unplug the cable.
Old Jan 9, 2019 | 05:19 PM
fordpride's Avatar
fordpride
But that wasn’t the question. The question was how to remove the pcm and there is no need to remove the e-brake to remove the pcm. If he would have asked how to remove a chip the I would still say remove the pcm. No point in fighting with that small hole to save a few minutes worth of work. If the cable is touted correctly that won’t be a issue
Old Jan 9, 2019 | 08:46 PM
fluidp's Avatar
fluidp
Thanks Guys.. Piece of cake. had it out in 15 min.. Will put my other PCM in tomorrow and fire her up.. Heres hoping my little issue is solved...
Old Feb 25, 2019 | 09:54 PM
pilgrimbizket's Avatar
pilgrimbizket
what was it issue?
PioneerODR
Jul 31, 2012 10:45 PM
BuckHammer
26
May 15, 2012 04:44 PM
qadash
21
Aug 4, 2011 01:09 AM
flipklos
Jul 27, 2011 03:26 PM
wolfe1104
Dec 15, 2006 05:08 PM
