this was out of a 97 f250 psd automatic. Contacted many salvage yards but they are unable to locate a unit with these numbers. Im searching for a 97 psd automatic PCM (colorado).
Try car-part.com, they will call it an "Engine Computer", then you need to know Auto or Manual trans, Low (Cali) or Standard (Fed) Emission, and the part # is very helpful. Did a search for MT, std emis (Fed), ID F7TF-12A650-SB and found a 1997 F350 5sp 4X4 for $85 out of Ohio. Hope this helps.
Unit above is DPC-203. Looking for 202. I dont know the part number.
All you really need is the Code .... like NAW4 , TDEO, TDE1, and TEE4 / TEE5 will all work on your truck ....... It is a Automatic 49 State model correct ? with single shot ( AA's) injectors ?
