question about trailer brake controllers??
Old 01-07-2019, 08:40 PM
carl2591's Avatar
carl2591
carl2591 is offline
friend has a 2008 explorer that does not have tow package. They were looking at getting 2" class II hitch, light hookups and trailer brake controller. I was asked if you can put a brake controller without the tow package in place..
can the brake controller be hooked up in this case. I know in my 2003 f-250 there is a plug under the dash for a brake controller and the plug in's, 7 and 4pin, connectors are in place near the hitch.
If so, what is the best way to make it work. They will be pulling a 3500 lb T@G trailer around the US this year sometime.
Old 01-14-2019, 12:28 PM
minimalist's Avatar
minimalist
minimalist is offline
I am using a Tekonsha wireless brake controller and am happy with it. The nice thing is that it will stay with the trailer and will also work with other vehicles that do not have a brake controller. All you need is 12v. I believe that can come also from the battery but I am not sure.
Old 01-17-2019, 09:08 PM
Benztechnc's Avatar
Benztechnc
Benztechnc is offline
class 2 hitch is up to 3500 lbs. if the trailer advertised weight is 3500 lbs, then they are going to want a class 3 or 4 or something bigger, because they will be over the recommended weight. From all my reading the number advertised is dry or empty weight, and when you start loading it, it goes up.
Unless you are talkjng about gvwr. But still i would think a little bigger hitch might be nicer.
M-S-G
04-14-2015 07:52 AM
wallz
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-05-2011 10:26 AM
KSMike
1997 - 2003 F150
10-04-2010 01:41 PM
FFemt5287
07-19-2007 08:11 AM
bas157
13
05-15-2006 08:09 AM
Quick Reply: question about trailer brake controllers??
