Hello from Raleigh
Old Apr 29, 2019 | 10:01 PM
  #61
Sparky83's Avatar
Sparky83
use to be you could run vintage tags if it was 20 years old... wonder why they changed it to 35...
Old Apr 30, 2019 | 06:33 AM
  #62
Benztechnc's Avatar
Benztechnc
different states, different rules. The above is what I’ve always remembered.
Old Apr 30, 2019 | 07:44 AM
  #63
Ug666's Avatar
Ug666
I got a 79 'Farm Use' plate recently when owner let me take any materials I wanted out of a tumbledown house. Still looking for a 73 though.
Old Aug 2, 2019 | 10:04 AM
  #64
superspost's Avatar
superspost
Resurrecting this post from the grave i have some minor progress to report. After soaking it in penetrating oil for days and days, applying heat and cold, hammering at it like a lunatic the distributor finally gave in an popped out. I wish i had recorded that satisfying pop on video when it finally jumped out. Here a few pictures of the culprit:
Needed some extra force
look at all that grime and dirt
Old Aug 2, 2019 | 09:07 PM
  #65
Ug666's Avatar
Ug666
That engine must be worth a bit, it looks like it still has the original Ford oil in it...
Congrats, I just got mine running again today.
It's the little triumphs!
Old Aug 7, 2019 | 07:53 AM
  #66
Benztechnc's Avatar
Benztechnc
So time for a new dizzy and getting the timing right.
Then the rear end or have you found anything else to deal with?
Old Aug 7, 2019 | 09:00 AM
  #67
superspost's Avatar
superspost
I am hoping, that that will make it drivable, but one thing always leads to another....
Old Aug 7, 2019 | 09:02 AM
  #68
superspost's Avatar
superspost
Couldn’t agree more!!!
Old Aug 12, 2019 | 09:10 AM
  #69
Benztechnc's Avatar
Benztechnc
Alright. So what's your update after this past weekend? Anything good to report?
Old Aug 12, 2019 | 01:01 PM
  #70
superspost's Avatar
superspost
I have installed the new distributor yesterday and did attempt to get the timing right. After setting initial timing (without advance) to about what i believe might be (its what the marks are saying, not necessarily true) 8 deg before TDC the engine was still running a bit rough. I adjusted it for sound and ended up somewhat higher... but relatively smooth sounding....
Then I took it for a spin around the block to test it under load but there was a noticeable hesitation when accelerating from low rpm... After increasing the idle speed some it got better but, was still there... Somehow i thought maybe it is related to the idle/mixture screws and tried to adjust these but failed to correct the issue.
At the moment I am thinking, that I need to check first whether the zero marking is really TDC or whether it has shifted and then start adjusting the timing.
But maybe there are two different issues - Timing and Carburetor/fuel supply...
Despite not having solved everything - it felt great to hear the engine running again and taking it for a spin. The engine felt like it had much more power than before, even got the tires to slip some on takeoff... So the carb rebuilt and dizzy have done something.
Hopefully, the remainder is just a tuning issue...
Old Aug 12, 2019 | 02:39 PM
  #71
Benztechnc's Avatar
Benztechnc
Niko,
You are now getting to the point where it's running fairly solidly and into fine tuning the engine running, right? So be open to other possibilities, such as the engine having excessive wear and tear or other similar items. Just thought I might put that out there.
There are plenty of tests yet to do, that will narrow down what the issue is, with the dizzy set and the carb adjusted.
Old Aug 12, 2019 | 04:23 PM
  #72
77mud's Avatar
77mud
Try bumping initial timing up to around 12° and see what that does.
Old Aug 13, 2019 | 10:31 AM
  #73
superspost's Avatar
superspost
Niko,
What would you suggest to test next?
Old Aug 13, 2019 | 10:32 AM
  #74
superspost's Avatar
superspost
will do. I ordered a TDC indicator that should arrive tomorrow, so that i can check whether the markings are actually correct....
Old Aug 13, 2019 | 12:36 PM
  #75
fuzzy1626's Avatar
fuzzy1626
Tune it by ear. Advance the timing until it pings under acceleration. Then back off in small increments until it stops.
Have you checked the accelerator pump or pumps for fuel spraying?
