Why is payload so important?
Old Jan 5, 2019 | 08:17 AM
  #31
Joe T's Avatar
Joe T
I still do not understand why the video advises people to consider a vehicle they aren’t licensed to drive. That is the definition of gross negligence if you were to get into an accident.
I’d be more worried about that personally.
Old Jan 5, 2019 | 08:19 AM
  #32
Joe T's Avatar
Joe T
Also I looked it up and the fine is actually $60 per ton you are over weight. Pay your taxes.
(I said $50 in my original post here)
Old Jan 5, 2019 | 12:35 PM
  #33
Tricon's Avatar
Tricon
Originally Posted by bobv60
The guy doesn't know what he is talking about. Just some IDIOT that wants to make himself look important by posting on the internet.
Says the idiot, trying to make himself look important on the internet...the irony is palpable haha.
Should we listen to 3 lawyers quoted in a major publication, or some BillyBob on the internet that thinks he know's it all? I know where I'm putting my money.
Old Jan 5, 2019 | 01:44 PM
  #34
ExxWhy's Avatar
ExxWhy
I missed that part, what vehicle was that?
Old Jan 5, 2019 | 02:14 PM
  #35
Joe T's Avatar
Joe T
Its the crux of the video is get a truck over 10,000 GVWR.
Thats where things get sketchy because over 10,001 your licensing and surveillance can start changing.
A srw f350 might be on the borderline but much more and you probably need a CDL and if it’s under CDL a 250 will most likely be able to pull it. If anything commercial 10,001+ you need to keep log books. This is when gross negligence by definition comes into play.
Old Jan 5, 2019 | 02:22 PM
  #36
00t444e's Avatar
00t444e
I depends on where you live, here you don't need a CDL until you are over 26,000 lbs, and you are even exempt from that if it is for personal or recreational use.
Old Jan 5, 2019 | 02:24 PM
  #37
bobv60's Avatar
bobv60
Each state is different but most states you can drive a truck or rv for personal use without any extra lecencing.
I have a F450, no special license required as long as i do not haul for pay.
In Oregon, there is basicly no limit on weight can tow if its a RV for personal use. Just have to stsy under the 80,000lbs gvw, 20,000lbs per axle, and under the tires weight limits.
Any type of utility trailer over 8,000lbs requires comercial plates and licensing.
As you can guess thrre are a lot of heavy duty trailers licenced to 8,000lbs in Oregon
Old Jan 5, 2019 | 02:26 PM
  #38
Joe T's Avatar
Joe T
I’ve never seen that just 26,001.
Old Jan 5, 2019 | 02:40 PM
  #39
bobv60's Avatar
bobv60
That is totally within your rights.
Doesnt change that this guy doesnt know what he is talking about.
I had a CDL for several years.
I drove truck on the farm for 20 years before this guy was born.
what he doesnt understand is that the weights and payloads that OEMs post on their trucks are not legal maxes in the USA.
Often, its about kepping a vehicle in a certain class.
Class 2 trucks (F250, 2500) max at 10,000lbs.
Some states this is the max GVWR you can own and NOT be a cormercial vehicle. So people want F250s there
Same with an F450, its a lot more truck that a F350DRW as far as tire and brake capacity, but its rated the same as a F350DRW to keep it as a class 3 truck, 14,000lbs. Anything more and there are EPA, licensing and insurance, and driver restrictions.
What the lawers said is you need to know the capibilties of you vehicle. Yes, you might have a problem if you are over them and it can be PROVED that that caused the accident, so you can be lible, and you insuance would have to pay, and you COULD go to cort. BUT that is no different than going 10mph over the speed limit and causing an accident. Last time I was on the highway, almost everyone, including RVs, where well over the posted speed
The most likely thing thst will happen to a heavly loaded vehicle that caused an accident is cited for following to close or driveing too fast for the conditions.
again, the door jamb numbers are NOT legal limits in all the states in the USA i have checked.
There are some provenances in Canada that DO go by the door jamb weights.
i posted a few different links here that SHOW that.
The poeple that think that being under a certian number makes the SAFE are the most dangerous.
As the weight of a vehicke incresses, thr dynamics of that vehicle canges. A rig one pund under the door jamb weights going 20mph over the speed limit with a driver that never drove a truck or hauled a traler is much more dangerious that a rig one pound over, at the posed speed FOR TRUCKS, with an experanced, aleart driver.
Old Jan 5, 2019 | 02:56 PM
  #40
Joe T's Avatar
Joe T
I looked it up and the licensing varies by state.
You still generally have A, B, C licenses which can be applied to personal/recreational and then CDL-A, CDL-B, CDL-C.
I think the whole video missed the mark because you can change your “payload” at the tax office. He didn’t mention the important weight ratings and licensing requirements.
I’m happy with my F250 as it’s most legal for my situations.
Old Jan 5, 2019 | 03:05 PM
  #41
Joe T's Avatar
Joe T
And you can almost get to 26000 with an F250.
Also there is different licensing even if not commercial.
Old Jan 5, 2019 | 03:11 PM
  #42
bobv60's Avatar
bobv60
Not in ALL states.
I DO NOT need anything other than a standard licence and I can drive any size RV, FOR PERSONAL USE, in Oregon. There are also several FARM exclutions in most states also.
Some of those big horse trailers with living quarters are HEAVY, no special license for them, as long as "not for hire"
Old Jan 5, 2019 | 03:21 PM
  #43
Joe T's Avatar
Joe T
Look it up because even in texas you may not need a CDL but a class A or B private. Not a major issue but necessary with an f350.
Edit: even with farm plates
Old Jan 5, 2019 | 03:34 PM
  #44
ATC_F350's Avatar
ATC_F350
According to the DOT experts I've talked to, as long as you don't exceed any of your components ratings (tires, axle, hitch, etc.) and not over 20k per axle, you are legal. GVWR is a number for Ford and has nothing to do with a legal DOT load. GAWR are the numbers you look at. Theoretically, you could pull one of the Australian road trains with a Ford Ranger, if you could get a strong enough components.
Old Jan 5, 2019 | 04:33 PM
  #45
ExxWhy's Avatar
ExxWhy
Yes, it varies by state. A quick search and I could not find a state that requires a different license for a typical 350/3500 truck when used for non commercial purposes. I may be wrong. A few require a different class license for long and/or heavy RV's, though I seriously doubt it is difficult to get one aside from paying for it. Some charge for plates based on weight, many (even most??) do not. In Ohio, a non-comm plate for a 250 is about $50, and about $85 for a 350. Obviously in some locations there is a big difference.
