B&W companion with 1/2' mat: Anyone installed one?
Old 01-02-2019, 10:49 PM
grantrekker's Avatar
grantrekker
grantrekker is offline
I am outfitting a new 2019 f450 with a Companion base for factory installed pucks. I also want to protect the entire bed with a rubber mat of 1/2". Can't find a mat with precut puck and gooseneck holes. Has anyone done this install? If so, cut out of just the holes or cut a larger rectangle the size of the entire base, or, ???
Old 01-03-2019, 08:46 AM
Army RET's Avatar
Army RET
Army RET is offline
(protect the truck bed) - do you also tuck it in at night?
Old 01-03-2019, 11:15 AM
kgburns's Avatar
kgburns
kgburns is offline
I'd just get the bed Rhino lined, but that's me. (I did mine)
Old 01-04-2019, 07:45 AM
lariatbob's Avatar
lariatbob
lariatbob is offline
Here is mine with a Bedrug. Only cut out the puck holes as I will probably never use the Gooseneck and can cut it out if I ever do.
Of course the Bedrug foam will be much easier to cut than rubber mat, but you get the idea.
Old 01-04-2019, 08:11 PM
Baldicon's Avatar
Baldicon
Baldicon is offline
I made a rectangular cut (with rounded corners) for the two sides of the hitch for the puck connection. The mat under the hitch between the two cutout areas is still intact.
Old 01-08-2019, 05:53 PM
grantrekker
yes, with it's own binky and thermal blankie!
Old 01-08-2019, 06:01 PM
grantrekker
[QUOTE=lariatbob;18398101]Here is mine with a Bedrug. Only cut out the puck holes as I will probably never use the Gooseneck and can cut it out if I ever do.
Of course the Bedrug foam will be much easier to cut than rubber mat, but you get the idea.[/QUOTe
thanks @lariatbob and others foryour insight, I wasn't sure if the companion rails would bottom out on the rubber and interfere with a solid metal to metal torque downat the four attachment puck posts.
Old 01-13-2019, 11:42 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
just the holes.. I used a hole saw on my drill to cut them and some extra trimming
Old 01-14-2019, 05:48 PM
grantrekker
OK, I see what you did on the doughnut cuts, looks nice. But, when I put my companion into the pucks without any mat, the clearance between the metal bed and the Companion was less than 1/4" at all places other than where the puck holes are. My concern was that while the pucks may be fully engaged, the Companion base is resting on the rubber mat and prohibiting metal to metal torque due to the metal resting on the rubber. Maybe that is an OK thing though. Any concerns that this could give an unstable connection when torqued to 80#?
Old 01-20-2019, 06:07 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
The metal pads on the B&W hitch are touching the metal sockets of the hitch locations.
Old 01-21-2019, 07:55 AM
Baldicon's Avatar
Baldicon
Baldicon is offline
What do you torque to 80#? Bought my hitch at the RV dealer and they installed it.
Old 01-21-2019, 08:10 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
the 4 bolts on each side that hold the arms for the head to the base.
see the documents here https://www.bwtrailerhitches.com/pro...ion-ford-pucks
Old 01-21-2019, 08:12 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
without any mat, the base ONLY touches the 4 puck positions.. so the rest of the bed adds nothing.. in the gooseneck type attachment the bed surface matters..
only the arms are torqued to 80 ft/lbs that isn't affected by anything else.. this base is REALLY strong
Old 01-21-2019, 08:22 AM
Baldicon's Avatar
Baldicon
Baldicon is offline
Thanks, I'll check them before I tow again.
ibuzzard
21
05-30-2019 11:38 AM
Craeshe
Modular V8 (4.6L, 5.4L)
04-22-2019 01:06 AM
guns
04-09-2016 10:40 AM
C. Lee Colbert
1983 - 2012 Ranger & B-Series
08-18-2013 01:00 AM
mzimmers
Paint & Bodywork
08-09-2003 09:11 PM
Quick Reply: B&W companion with 1/2' mat: Anyone installed one?
