351c to EFI kit, help determining
Old Jan 2, 2019 | 12:20 PM
milkweed.gardener's Avatar
milkweed.gardener
I have a 351 Cleveland motor with an Edelbrock model 1405 carburetor (600 CFM, 4 barrel/venturi) currently mounted on it that the previous owner installed.
I would like to switch to an EFI system.
I'm thinking:
https://www.fuelairspark.com/fasttm-...fuel-pump.html
FAST EZ-EFI Fuel Master Kit, Inline Fuel Pump
Be the first to review this product
New FASTTM EZ-EFI® Fuel self- tuning system updates throttle body, electronics & harness from original version while maintaining ease of use
IN STOCK SKU 30227-06KIT
but I don't know hardly anything about this stuff to know what to watch out for.
Are the carburetor mounting bolts a standard configuration, that any carb to EFI swap will mount?
or do I need to find a EFI kit that specifically says it is for a Ford 351C ?
As far as I know, the intake manifold is Ford stock that originally came with the engine, is there an easy way to confirm this?
I have seen replacement intake manifolds for sale, which if I understand correctly is to improve performance (power output).
I only drive the truck to work and back and to a restaurant for lunch, would there be any practical benefit to replacing the intake manifold? (smoother engine firing, better gas mileage)
Thanks in advance.
yukgoon
Dec 21, 2005 11:04 AM
duece_bigalo01
Aug 28, 2005 09:07 PM
78RangerXLT
Oct 19, 2002 09:06 PM
mmcannally
Apr 3, 2002 07:32 PM
