Hey guys, I ordered a 2* caster shim from WFO. Yes I failed to see that they are sold singly so I have a second one on the way. Problem is I am tearing into my Ex tomorrow to replace ball joints, steering gearbox and other suspension stuff. I was planning on putting the shims in while I had the front end torn down. Is it ok to run the shim on one side but not the other for a few days?
I would rather only have to break down one side twice rather than both sides twice to put the shims in. Any suggestions?
Well on second thought, I don’t really think it is a good idea because it will probably induce some steering issues being uneven caster from side to side. I just hate having to do work twice......
The axle housing can’t twist but the springs can, you would end up with about 1* of additional caster.
its an old school jeep trick, need 2* of additional caster but only have a 4* shim, Split it and install the 4* on one side and let the springs fight over it. Same thing with your 2* shim.
I'm still a X newbie, Is this issue the same as having 3-4" of play in the steering? I have that and am planning to change the steering box to correct it.
Thanks,
Dan
no
these shims are to dial in your alignment.
steering play is from worn out components.
steering gear
Pitman arm
steering column/shaft
tie rod ends
drag link ends
