2001 excursion part 2: extra cylinders, extra features
Old Sep 29, 2021 | 06:43 PM
96firephoenix's Avatar
96firephoenix
Well, about 13 months after selling my 01 XLT 5.4, i scooped up an 01 LTD 6.8. Has some cosmetic issues and some electrical faults, but nothing i can't handle.
Almost no rust, relatively speaking. Definitely not beyond salvation
Old Sep 30, 2021 | 09:22 AM
WE3ZS's Avatar
WE3ZS
Congrats!
Looks like a pretty solid base to work with.
Good luck with it.
Old Oct 17, 2021 | 03:15 PM
96firephoenix
Changed the spark plugs on it (all 10 with no major issues, I'll take what i can get) and popped a compression tester on there while I had it open...
Entire left bank read 90psi
Front 3 on the right bank read 140 psi
Back one on right bank read 30 psi
Didnt bother getting a reading on the second from the back.
All 9 cylinders that I checked read a solid 170 with a bit of oil dripped in on top to seal the rings, so at least i know whats going on with the engine - just sucks 😆
Old Oct 18, 2021 | 08:43 AM
96firephoenix
soooo, couple questions for the gang:
  • any reason I can't put an EGR equipped engine into a non-EGR truck? I assume I'd have to remove the EGR provisions from the engine, but there's not some hidden nonsense I don't know about?
  • Is there any market value in a 200k mile v10 that needs a ring job? the valves held good compression, so maybe the heads are worth something?
    • otherwise, I'm stripping it down and scrapping it.
Old Oct 18, 2021 | 09:16 AM
Antonm's Avatar
Antonm
Why not re-ring the engine that's in there? You know it fits and everything hooks up correctly.
If the engine is running and a huge cloud of oil smoke isn't following the truck around everywhere , then the worst case scenario would be a slight overbore and new pistons (best case would be a giggle ball hone and new rings).
Old Oct 19, 2021 | 09:30 AM
96firephoenix
Honestly, I value my own time more than that, and there just isn't a solid business case for me.
I can get a Used v10 for $1-2K, and doing a piston re-ring will cost about $500 in parts alone, assuming I don't need to over-bore the engine, and then we're looking at another $200 in oversize pistons, and gets into the territory of "might as well do a full rebuild on the heads too, which pretty soon balloons into $2000 of parts and labor, which is nice to have a completely rebuilt engine, but I would rather just stuff a good used engine in.
If I'm going to be pulling an engine out and putting one in, I'd rather just put in a good used engine than tear down the current one and re-ring it, or take the risk of tearing it down only to find that it needs machine work, etc.
And there is a pretty good cloud of smoke following it around, so there's a good likelihood of needing a full rebuild with overbored cylinders.
Old Oct 21, 2021 | 01:22 PM
96firephoenix
pretty sure I have a broken front spring. Pass is flat, driver's is frowning.
should have gotten "THESEUS" for my vanity plate at this rate, lol.
adamsquared
May 4, 2020 03:14 PM
TrdLtly
Aug 27, 2012 08:21 AM
Peace2Peep
Jul 9, 2012 11:34 PM
Sunline Fan
Dec 29, 2011 01:43 AM
Blackwaterforge
Apr 6, 2010 04:57 PM
