I can’t get the video to play, hopefully it plays for you guys. It looks to me like the flexplate is vibrating back and forth as it spins, engine on.. maybe 1/8” up to 1/4”.
Damn just when I thought I found something. Is it supposed to make a light chirping noise too? I can feel something tapping at idle on the floor until I put it in drive or reverse too. I did verify that the transmission actually was replaced like the guy told me. There is a remanufactured tag on it so maybe it is good after all.
how about this? Right at the gear shifter. Now if I can figure out how to get the wires out so I can splice and make new connections. There’s no room to work with being that it’s right at the entry point of the shifter..
Well I finally got around to taking it for a test drive and what do you know, no flashing OD light. I never reset anything so I would assume it was a poor connection or the metal shavings on VSS.
