flashing overdrive light
Old Jun 3, 2004 | 06:35 PM
Bigger B's Avatar
Bigger B
Unhappy flashing overdrive light
Got a 99 f250 diesel w/ automatic transmission. It has 220,000 miles on it and has been a tow rig all its life. The overdrive light has been flashing on and off for the past couple of months. when taking off from a dead stop, it does take the transmission a little longer to upshift and sometimes downshifts funny at highway speeds. I tried 2 seperate actron code readers to read the computer, but they don't read it. Someone suggested that the torque converter maybe bad,but could always use a second or third opinion.
Old Jun 3, 2004 | 06:51 PM
phoneman's Avatar
phoneman
I believe the light flashing indicates the pump is gone in the tranny. Thats what I have been told before.
Old Jun 3, 2004 | 07:42 PM
Benjen's Avatar
Benjen
The light is just a general warning light, like the check engine light. It could be almost anything is wrong. The only way to find out is a code reader.
Old Jun 3, 2004 | 10:39 PM
03f150man's Avatar
03f150man
benjen is correct. the flashing light could be a wiring loom problem (external to the tranny) or who knows what.
Old Jun 4, 2004 | 11:37 AM
hookin'78's Avatar
hookin'78
Ahhh ........ the notorious flashing O/D light......... you need a new torque converter,.... I have fixed this problem to many times. Do you have any type of programmer on the truck? If so you can run your diagnostic codes and it will tell you what if it is the converter. Your symptoms are the same as all the ones I have fixed.
Old Jun 9, 2004 | 02:03 PM
DEG's Avatar
DEG
I have a 2003 F350 with only 7200 miles on it. Towed a 20 ft trailer last week and got the flashing O/D light with a check engine light. I took it to the local dealer and they told me that the codes all pointed to the module in the transmission. It was changed and less then 50 miles later I have got the light again with hard shifting. Have you heard of Ford having alot of transmission problems with their 03 models?
mtzorger
Modular V10 (6.8l)
Jul 29, 2020 01:23 PM
LanaKila Peck
Mar 4, 2016 03:23 PM
clemensfield
25
Aug 27, 2013 01:49 PM
gvsuman
Apr 27, 2009 11:06 PM
JoeLindaMiller
Oct 24, 2004 11:10 PM
