C6 fluid
Old Jan 5, 2019 | 05:57 PM
Franklin2's Avatar
Franklin2
Brass compression fittings are more of a permanent type repair. Hose is going to need maintenance eventually.
Old Jan 5, 2019 | 08:59 PM
1981 F100's Avatar
1981 F100
Ok thanks, I was leaning toward brass compression fittings, but wanted to make sure first
Old Jan 6, 2019 | 07:11 AM
FuzzFace2's Avatar
FuzzFace2
Why not use flare fittings?
I am sure the trany side uses flare and when the lines are removed from the trany the lines will have flares.
Get some lines with flares and 2 couplings to join them together.
Back in the late 60's early 70's AMC used rubber hose with threaded ends to go between the lines and the radiator.
I guess they were thinking there was movement between the lines & radiator and to keep from the lines or radiator leaking they used the threaded hose.
I would think if you wanted to use rubber hose hove a shop make them up as that would be better than slipping the hose over the line and using clamps.
Dave ----
madrox
Dec 10, 2009 07:23 AM
Sawbones25
May 18, 2007 07:04 AM
smoke n tires
Oct 13, 2004 07:31 PM
bigblocksix
May 24, 2004 08:12 AM
joe btrucks
Jul 19, 2002 12:41 PM
