separated standpipe
Old Jan 11, 2019 | 07:31 PM
TooManyToys.'s Avatar
TooManyToys.
Sometimes you can just side load the tool and bolt to get the bolt from turning, and depending on the situation I may use my thumb ratchets or go powered with the Milwaukee 1/4 if there's room.
Old Jan 11, 2019 | 08:40 PM
namnguye's Avatar
namnguye
Yes, that's a good trick. That day, my head wasn't working right. Probably too tired to do anything right.
I used left hand finger to press on top to create some resistance. It works sometimes, but it wasn't very good. Maybe tilted the tool just a bit to unwind the wrench would work well like you said (is that what you meant side load?). After all was done, I realized I used the hand squeeze ratchet before for this part.
Old Jan 12, 2019 | 01:02 AM
Yahiko's Avatar
Yahiko
I have a very loose Apex bit holder that I put my finger on the top and use the other hand to rock it back and forth.
Also when I say loose I am talking the ratcheting action. The tool does a very good job holding the bit. Here is the tool.
https://www.lowes.com/pd/Kobalt-35-P...ol-Set/3387640
Now with out getting into all the math. This tool also works for torquing the bolts back down. So long as you stay at 90º
you don't have to add or subtract from the torque value. This is a lot easier with some diagrams that I don't have right now.
The simple answer is if you add from the pivot point or subtract from the pivot point then the torque value changes. If you at
90º to the pivot point then your not adding or subtracting. The one other thing that will screw things up is tool flex or twist.
So that tool I listed above is OK for light values. It is going to flex some.
Old Jan 13, 2019 | 03:00 PM
Mich6.0's Avatar
Mich6.0
Well here is another observation I have noticed my original standpipes have a spring loaded valve in it and the new updated one doesn't . Anybody notice this little bit of information when they did theirs.
Old Jan 13, 2019 | 05:20 PM
namnguye's Avatar
namnguye
I think you may have it backward. The updated one has a 1 way valve so it keeps oil. That way, after sitting over night, it has all the oil need to start right away.
Old Jan 13, 2019 | 08:03 PM
Mich6.0's Avatar
Mich6.0
don't have it backwards, new one if you separate you can look straight thru the tube or shine a light thru the oil passage holes and see the light. I will call Bear lake tomorrow and ask them to pull another and check .
Old Jan 13, 2019 | 08:43 PM
Yahiko's Avatar
Yahiko
The check valve is in the top half and to get at it you have to unscrew the section.
Never mind that top section in the last photo on the left side. That is one of the old ones.
Kdawg89
Sep 30, 2019 07:26 AM
jstihl
May 6, 2017 06:35 AM
blowin_smoke_1977
Apr 25, 2013 06:53 PM
Links56
19
Dec 24, 2009 07:47 PM
brian42
16
Dec 21, 2009 07:28 PM
