just a few questions about injector removal
ok so ive been watching you tube videos on injector removal while waiting on my parts and have a few things im not 100% on.
1. What should i do if i can't get the small allen head oil plugs out? ive heard they can seize up and are easy to strip out. also is this going to dump oil all over?
2. worried about hydro lock, is there anything else to do other than start with the injector in the back on each bank, and pull out oil plugs?
3. from what i can see in you tube vids, there is two hold down bolts per injector and they say to pull out both bolts, BUT i noticed on one of diesel tech rons vids that he said you only have to pull out the bottom bolt, slide a mechinism up and then pry the injector out with pry bar. I just want to clear up if you should pull both bolts or not? any advice or tricks on getting the injectors out or back in?
4. I read in a write up on riff raff that i need to fill oil rail , and hpop with fresh oil once everything is back together .where do i fill up the oil rail?? Also is there anything i need to do other than cycle key on and off several times before i turn over the engine for the first time?
thanks for any input on these questions and please feel free to let me know of any problems, pain in the *** parts of this job, or anything that will make this job go smoother. You guys rock!!
Sometimes ya just gotta crank it to get oil back in there - like the example below.
I haven't done this yet, but like you am thinking about doing it for the F350 I just acquired. One option appears to be taking out the glow plugs after injector fit and hand turning the engine with a ratchet on the fly wheel which forces the any oil and fuel out. Not sure how those that have done this before feel about that?
The glow plugs should really come out first - this helps with getting the injectors out. In the right piston/valve position and glow plugs in, the O-rings can create a vacuum as you try to pull the injector (think piston over sealed chamber), making some of them really stubborn. The same goes for installing the injectors - they can build a little compression. This a good time to inspect/replace your glow plugs anyway - they're 10 bucks each. NO AUTOLITES!
Again you have to do this with the plugs out. Remove them before removing the injectors, and install them after the injectors are in and you've turned the engine over.
Honestly I don't even know that it's necessary to evacuate all the cylinders with a vacuum pump unless you plan on changing the injector cups also (and I wouldn't unless you're having a problem with them). The rear cylinder will be full of oil and fuel so I would not use the starter bump method to turn the motor if you leave a lot of fluid in there. Even cranking by hand the fluids shoot out quite violently. I would not want to be near if it someone bumped the starter with the valve covers off.
Obviously the cups need to be reasonably clean when you install the injectors, so you'll have to clean up the mess you just made either way.
Thanks for all the input guys. i already bought the pnuematic vacum so i will go ahead and use that. am i supposed to put the suction tube in the cylinder and glow plug hole to suck out the oil/fuel?
Also ive heard that the copper washer on the bottom of the injector doesn't always stay snug( diesel tech ron). is there a trick to keep the washer from falling off? ron mentioned something but the audio wasn't clear.
You can use either the injector nozzle hole or the glow plug hole - they both do the same thing.
I don't put the copper washer on the tip until after I've oiled the tip. The oil helps to keep the washer on there because it forms a mild vacuum with seal around the edges. I've never had a copper washer slide down since I started doing this.
majorgator
02-23-2015 06:51 AM
Gonzo77833
19
05-08-2012 10:48 PM
