Offroad & 4x4
Hub locknut wrench
Old Sep 28, 2003 | 10:37 AM
MustangGT221's Avatar
MustangGT221
Hub locknut wrench
My uncle has an F-250 and it appears to be the d50 axle. It has auto hubs, which we're swapping for warn hubs. I took the hub apart, and didn't have the correct socket for the locknut. My F-150 has the hex like one, which is the same kind of nut on my uncles truck. However, mine didn't fit, it was too small. My dad's truck has the one with the 4 prongs on it, that aint it. My uncle went to autozone and it doesn't appear that they have one. What the heck is goin on? I know it's the hex like socket, but not sure what size.
Old Sep 28, 2003 | 01:59 PM
natewoz's Avatar
natewoz
I'm assuming you had the auto hubs with the 3 bolt holes in the cap. You're installing the spindle nut adaptor kit, right? I finished my swap yesterday afternoon. My hubs had the 5 bolt cap which didn't require the adaptor kit. If your dad's truck is a 150, the 4 prongs are a lock washer between the two nuts. the nuts are actually round with 4 square notches milled into it. A picture would help if it's convenient.
Old Sep 28, 2003 | 04:17 PM
MustangGT221
My uncle has the 3 screw auto hub, I got the conversion kit and hubs from Warn. My dad's is the same truck as my uncles, but my dads is an 88 vs a 96 and my dad's came with manual hubs stock. I can't find a socket that will fit my uncle's truck. I know it's the hex type one, it's not the 4 pronger like my dad's F-250. My F-150 has been changed to manual hubs, and it uses a hex locknut but it's not as big as the one on my uncle's truck, so my socket doesn't fit. The warn set seems to have the 4 prong locknut to go back on, which I have a socket for that. I just need the hex socket to get the old locknut off.
Old Oct 2, 2003 | 09:42 PM
Franken-Truck's Avatar
Franken-Truck
doesn't the 250/350 have a 5 pronger?
Old Oct 4, 2003 | 08:35 AM
AlM's Avatar
AlM
yo, 95-96's have a diff design locknut than earlier years:
http://www.autobarn.net/xxx6010.html
prob #OTC6796
AKHunter93
17
May 31, 2015 04:30 PM
AKHunter93
19
May 31, 2015 09:56 AM
big-bro
Jan 10, 2014 04:55 AM
gliattall
Oct 23, 2009 07:41 PM
bremen242
Offroad & 4x4
Mar 20, 2005 05:09 PM
