Help! Did I Mess Something Up?
Old May 29, 2015 | 04:21 PM
AKHunter93's Avatar
AKHunter93
I just replaced the ball joints in my '88 F250. It has a Dana 44 HD axle.
When I pulled the hub locknut, the whole rotor/hub assembly came right off. I left the wheel bearing, lock nut, all of it right inside the hub assembly while I replaced the ball joints. When I went to reinstall it, I slid the whole shebang over the spindle, made sure everything was seated all the way back, and tightened the locknut down again.
But now I'm reading that there's an inner locknut too?
There was only one I had to loosen to pull the assembly, if there was an inner nut then wouldn't I have had to loosen that as well before the hub assembly came loose?
I test drove it after I put everything back together and it all felt fine, but I definitely don't want to ruin something.
Old May 29, 2015 | 10:04 PM
AKHunter93's Avatar
AKHunter93
Bump cuz I need an answer
Old May 29, 2015 | 10:59 PM
genscripter's Avatar
genscripter
I got a van, so I'm not much help for you. This is more of a Diesel specific forum. Not that the guys here couldn't help you with your steering/suspension issue, but you might get more generic advice from the 1987-1996 Ford Truck forum: 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old May 29, 2015 | 11:32 PM
AKHunter93's Avatar
AKHunter93
Thanks, I didn't realize I placed it in the wrong forum. Reposted in the appropriate section.
Old May 29, 2015 | 11:37 PM
genscripter
Can't hurt to post in both sections. The IDI section has the friendliest and most helpful guys out there, so you'll probably get an answer from them as well.
Old May 29, 2015 | 11:45 PM
AKHunter93's Avatar
AKHunter93
I sure hope so. It's my daily driver, so I can't afford for it to go down. But I also have a thing about doing the work myself!
Those guys do know their stuff though, I'm sure it'll get straightened out.
Old May 29, 2015 | 11:47 PM
Macrobb's Avatar
Macrobb
Take pictures? I've torn mine apart once, but don't remember how things looked.
Old May 29, 2015 | 11:58 PM
AKHunter93's Avatar
AKHunter93
I didn't take any pictures, it's all back together now.
When I disassembled it, this is how it went: (forgive me for not using proper names)
Pulled 6 hex bolts from hub locker, remove hub locker
Remove snap ring on end of axle shaft
Remove retaining screw that holds the gear that slides over spindle
Remove the gear and the spring behind it
Remove wire retaining ring from ID of hub
Remove large gear assembly
Unthread hub locknut from spindle
Leaving locknut and all pieces in the hub, I pulled the rotor/hub assembly off the spindle
Assembly was exactly reverse.
My thinking is that, if there was a second locknut to unscrew, then I would've had to do that before the rotor/hub assembly could come off of the spindle, right?
Old May 30, 2015 | 02:24 AM
tecgod13's Avatar
tecgod13
There is definitely supposed to be two nuts you have to remove. Generally there is an outer locknut that is really tight, then a special washer of sorts that engages a tab or slot in the spindle and somehow holds the inner nut from coming loose. The inner nut is only torqued to some lower number that keeps the bearing tight, but lets it spin easily.
The 10.25 sterling rear axle has a special ratcheting locknut that works like one piece, but other than that you should have a second nut in there to keep things from loosening.
Old May 30, 2015 | 07:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
as said above, there is supposed to be two nuts and an indexing washer.
can you drive it safely the way it is? yes, for a while. but i would get the parts to put it back together properly. the way it is now, the lock nut can loosen up and the bearings will commit suicide.
Old May 30, 2015 | 09:34 AM
AKHunter93's Avatar
AKHunter93
Well that's not exactly what I was hoping to hear. But thanks for your input. I'll track down a parts diagram to compare to and see what I need. Who is a recommended manufacturer/vendor if I do need to buy these locknuts?
Old May 30, 2015 | 09:56 AM
tjc transport
i ain't rite
no idea, i never had a D44. the one truck i had with a D-50 IFS was converted to a D60 solid axle within 6 months of purchase.
Old May 30, 2015 | 11:27 PM
AKHunter93's Avatar
AKHunter93
Hey Tom, I posted this issue in the IDI section as well, and somebody posted a picture of the Dana 44 HD parts diagram that only shows one locknut.
What gives? Is it possible that the same axle had slight design differences in different vehicles like F150, F250, Bronco, etc?
Old May 31, 2015 | 07:00 AM
tjc transport
i ain't rite
it could be.
or i may be wrong and the 44 only had the one lock nut.
it is not like i have never been wrong before, and i am sure i will get something wrong again.
unlike what my ex wife told everyone she met, i AM NOT a perfect a-hole.
Old May 31, 2015 | 01:18 PM
tecgod13's Avatar
tecgod13
There needs to be something to keep the nut from loosening, unless its a weird design like the ford/sterling 10.25 rear end which has the ratcheting nut. Otherwise as the hub rotates it will loosen up from the motion.
Unless its setup like a trailer axle where there is a castle nut or fancy pronged washer over the nut that takes a cotter pin. But I don't think that would work right with a locking hub....
