one expensive idi
https://www.ebay.com/itm/1985-Ford-F...3:pf:0&vxp=mtr
then have to drop another 5-6 grand into it to make it roadworthy.
sure you can just go out and drive it, but my bet is within 1,000 miles things will start leaking and breaking.
seen it way too many times over the years. and the people that brought the "almost new, no mile" vehicle to me then got pissed when i quoted them thousands of dollars to fix it. i tried to explain, but they just refused to listen because in their mind i was "trying to rip them off"
after a while i just refused to have anything to do with people and their "like new, no mile" vehicles.
At 43,ooo miles now, it has had the entire front end done twice, brakes all the way around 3 times, fuel tanks replaced, and wiring problems to pull out your hair.
Tires dry rot before the tread even thinks about getting 1/4 worn, and the paint fell off of the truck
The E4oD has been replaced twice
I could go on. Then there's the 02 f 350 diesel with 32,000 miles on it we pull the travel trailer. Yeah, it likes to spend money from sitting too.
Another thing about the truck in the ebay add. That speedometer goes back to 00000000 when its at 100,000. so IS IT REALLY a low miles truck?
I vote no, look at the numbers in the odometer, they are dropped down at the top. Usually when they roll over 100,000, the numbers crooked in the slots.
Also good to note, there are no pictures of the pedals where you would see wear, or the floor mat where your feet sit,
The truck may be a low mile survivor, but I have my doubts, and would pass.
That ia about $10,000 more than I would spend on a 4x2 with a single cab
I got the thing started right there with some ether, found that the slave cylinder was leaking badly. Got enough brake fluid in it to drive it onto my trailer.
After I fixed the clutch and drove it, a few things failed relatively quickly:
1. Vacuum pump. No lubrication inside it and it siezed within 1k miles. That took out at least one idler pulley
2. Water pump failed within a year/10K - might have just been original.
3. Alternator failed - regulator ended up shorting
4. Various front-end ball joints/tie rod ends.
5. U-joints, carrier bearing.
6. Return lines.
Over all, not a whole lot, but it hadn't been sitting *that* long either.
I'm totally used to replacing tie rod ends and ball joints - they seem to fail on a sitting rig
U-joints and carrier have failed on every single rig I've 'recovered' within a year, most right off the bat.
I just plain expect that any (cheap) vehicle I get is going to need "routine maintaince" work soon after I get it. That's just to be expected.
Still, that NA IDI non-4x is way overpriced. But judging by the pedals, that's a < 100K truck.
I'd give the guy $7200 for that truck. Cuz that's what it's worth. And when he complains, I'll tell him to find more money from the nonexistent other buyers looking for a slow-*** dually with no turbo from the 80's.
Not that it's a bad thing, but it's seen fresh paint and a gallon of amorall - though it does look to be in great shape despite the shine, but hard to say.. Interior is good and that adds a lot of value.
Wiper motor is tan, and pass side battery is black, suggests that it was repainted without taping off, but maybe the painter did well on the exterior and just had other things to do that day.
Overall, looks very nice.. Though it's 2wd, got the 4sp and diesel.. So normally I'd class this top of 2x4 price range of 10k, but mint intirior gets 2+ - - IF the buyer doesn't care for 4x4..
I think he's going to have it awhile, but ultimately get his 12k asking price, just speculation.
Low miles, out of service - if true, aren't so big a deal in every case.
Bonnie, my truck sat 10 years before I brought her back to life, and hauled 4k+ of stone 75 miles today _ passing toyotas.
tires, hoses and belts, drain and fill every fluid, return kit, new clutch... .
My case short term failures (few years) , lift pump, starter, thermostat, rear brake hardware, radiator started to leak.
Not so much really though..
Yes any sitting old truck is gonna need a sharp eye and 500-1,500 $ in parts, but in my trucks case anyway, sitting hasn't meant unreliable.. She went from 10 years out to pasture to daily driver strong now 8 years straight and runs like a top. we go the distance - often.
Always starts and idles to 'normal temp' before being driven.
I don't hot rod it, and keep rpms down below 2,500.. Even if people (they do) hate me.
I see many of our trucks listed 6-10k in Tennessee now a days, and almost all super beaters still fetch 2,500-3k.. And they sell I suppose.
Maybe local demand for diesel ford's here.
Though, people ask often if I will sell her, I wouldn't sell my truck for 10 grand, couldn't replace it for that.
Temptation if offered 15, can do alot with that kind of money, but really, I still probably wouldn't sell.
Though, maybe 10 - 15 years from now, the older trucks will become true classics.
I think these trucks will only appreciate in value, already seen the values pretty much triple since buying mine, and I think this trend will accelerate as people yearn for a simple reliable affordable alternative to what modern diesel trucks have become, and the pickings get slim.
- Supply + Demand * Condition = Value
Often hear said - of now valuable late 60's cars/'those were just beaters to us.'
I would buy a sitting or low mileage idi again, because I do my own mechanic work.
Bonnie just turned 34
