Trailer connected/disconnected messages
Old Jan 30, 2019 | 01:10 PM
  #31
TeddyD's Avatar
TeddyD
Fix for problem
the fix for the problem is to replace the 7pin plug. Ford used minimal dialectic grease in the wire harness. The wire harness is not water tight so corrosion happens really fast with the lack of grease. Ford has had a service bulletin about this problem. I was lucky as I had the option trailer camera system so I just popped out the factory 7pin and installed this one to stop all the warnings popping up. I went into the dealer and traded them the old 7pin for a new one. Don’t waste your time trying to clean out the plug or use a voltmeter.
Old Jan 30, 2019 | 01:53 PM
  #32
catrasca's Avatar
catrasca
It never happened again...
Old Jan 30, 2019 | 02:08 PM
  #33
TeddyD's Avatar
TeddyD
not so far and it’s been 2 months. The secondary plug I used was packed with a lot of dielectric grease so that will help for now. The replacement plug the dealer gave me again had very little grease. When the weather up here in Canada gets warmer, I will be adding dialectic grease and heat shrinking around all the electrical connectors by the spare tire. Ford missed the mark with the quality of electrical connectors they used.
Old Jan 30, 2019 | 02:48 PM
  #34
catrasca's Avatar
catrasca
I only had the one incident with messages coming on without a trailer hooked up and never again...
F350MS38RSSA
Oct 31, 2020 04:36 PM
JD'sBigredv10
Nov 18, 2018 09:47 AM
adgjqetuo
Sep 25, 2018 11:08 AM
Don Schuler
Jan 25, 2018 12:44 AM
Michael53
6.7L Power Stroke Diesel
13
Feb 25, 2015 05:51 PM
