Trailer connections
Old Jan 24, 2018 | 11:47 AM
Don Schuler's Avatar
Don Schuler
Trailer connections
Went to connect the trailer today and the truck said that the left turn signal lamp was out ,checked the trailer and it was working fine ,2 times in the past it has told me the trailer was disconnected while going down the road that's scary. Any thoughts???
Old Jan 24, 2018 | 11:50 AM
69cj's Avatar
69cj
Grounds and moisture in plug would be my 1st checks.
Old Jan 24, 2018 | 11:58 AM
Turbo Dog's Avatar
Turbo Dog
Might be time to replace the connector on your trailer harness. Mine was doing that and a new connector cleared it up.
Old Jan 24, 2018 | 12:00 PM
Don Schuler
Sprayed it before when had the no connect issue less than a mo ago never had issues with my other truck with this trailer
Old Jan 24, 2018 | 12:04 PM
sgeorge's Avatar
sgeorge
Mine did that and I found that the trailer plug was just a little loose in the truck plug. I ran two wraps of electricians tape around it to tighten it up and has been fine since.
Old Jan 24, 2018 | 01:56 PM
Texmudder's Avatar
Texmudder
Mine did this with my old trailer. It did not have the ground wire hooked up and was relying on the ball for ground. Hooked up the ground wire and never had problems past that time.
Old Jan 24, 2018 | 02:22 PM
Horsehaulin8's Avatar
Horsehaulin8
Neat idea, thanks!
My connector did that one time when hauling, I pulled over to the side of the road to make sure I was still hooked up! It hasn't done it since then, so maybe it was just a little too loose, but next time I'll do the tape.
Old Jan 24, 2018 | 02:40 PM
troverman's Avatar
troverman
The problem will almost certainly be the plug of the trailer harness. Sometimes the system can be a little slow to inform me via the screen that I have "disconnected" the trailer, but usually if you see that warning while driving it means the plug got loose for a minute and the truck lost the connection.
I've had a trailer work fine on my Raptor but give me turn signal errors on my Super Duty. The plug can be loose and yet all the main running lights are fine. Sometimes I'll wiggle the plug and see my lights flicker. Using electric tape to prevent slack, or wedging something else in between the trailer plug and receptacle usually works.
Old Jan 24, 2018 | 06:27 PM
Don Schuler
I did the tape thing today couldn't duplicate the problem thanks for the feed back
Old Jan 24, 2018 | 10:43 PM
F250Ninja's Avatar
F250Ninja
Same was happening with my trailer with warning and light out. Replaced the trailer plug. Made sure the tabs and pins were lining up good. Dielectric grease over everything.
Tomorrow I’ll be adding a few strips of electrical tape !! To avoid any play thx guys
Old Jan 25, 2018 | 12:44 AM
RainDesert's Avatar
RainDesert
Mine does it too, I will try the tape fix next time. Thanks.
srkr
May 3, 2025 04:02 PM
F350MS38RSSA
Oct 31, 2020 04:36 PM
JD'sBigredv10
Nov 18, 2018 09:47 AM
wb6anp
Jun 7, 2017 04:49 PM
Kris_kris
Dec 16, 2015 08:48 AM
