2015 6.2 Alternator
Old Dec 26, 2018 | 02:58 PM
06Dually's Avatar
06Dually
2015 6.2 Alternator
Does anyone know or know how to find out the amperage of the alternator on my 2015 F-250 6.2? Snow plow prep package? Thinking I need to go to a higher output unit...
Old Dec 27, 2018 | 01:37 AM
Franklin2's Avatar
Franklin2
Is there a name on it anywhere? They say the 200 amp version is made by Denso. The 150 amp version is made by Valeo.
Old Dec 27, 2018 | 01:40 AM
Franklin2's Avatar
Franklin2
Also look for some numbers.
6.2L, 200 amp, ID BL3T-10300-CA
6.2L, 200 amp, ID BL3T-10300-EA
6.2L, 150 amp, (ID CC3T-10300-AA)
Old Dec 28, 2018 | 05:51 PM
06Dually's Avatar
06Dually
so it's either 150 or 200 amp - those are the only two possibilities?
Old Dec 29, 2018 | 09:27 AM
Franklin2's Avatar
Franklin2
From what I looked up, yes. You would think 150 amp would be plenty. I ran a Meyers 7.5 ft plow on a f150 with a 60 amp alternator. It would not pick the plow up when I first installed it but once I turned the idle speed up a little bit it picked it right up and worked fine for years like that.
Old Feb 6, 2019 | 06:38 PM
pack4tag's Avatar
pack4tag
reason for my 200 amp option
Old Feb 7, 2019 | 06:01 AM
Franklin2's Avatar
Franklin2
What are you going to run with that inverter? The reason I ask, you might be able to get away with just buying a deep cycle or marine battery, and mounting it all in the back somewhere. If you are going to use it for short periods of time, the aux battery can supply the inverter, and then the trucks' charging system can slowly charge it back up as you are driving. This will also protect your starting battery from discharging and then you can get the engine started. You could keep the alternator you have. You have to remember also, that alternators do not have full output at idle. So when you go to use that inverter at full capacity, you will need someone to be sitting in the cab revving the engine to use it with a large load.
Old Feb 7, 2019 | 11:06 AM
pack4tag's Avatar
pack4tag
The inverter easily runs my rooftop Lance 13,500 A.C. when we are stopping off the grid.
I use a SEIC "stationary engine idle control" to maintain 1000-1200 RPM.The RPM to needed
for the 200 AMP output.
I ordered the truck and all the options.
The last new pickup I purchased OFF any dealer inventory was 1963. Searching the web did not
find what I wanted
Old Feb 7, 2019 | 11:21 AM
ford390gashog's Avatar
ford390gashog
There is a 320 and a 370 amp available from mechman. You will need 2/0 charge cable.
Old Feb 7, 2019 | 11:56 AM
pack4tag's Avatar
pack4tag
I am well satisfied with my current setup. Road tested and it works,flawlessly
TAT2DUP81
Mar 2, 2018 02:15 PM
waldreps
2004 - 2008 F150
Aug 13, 2017 09:53 PM
Gearheadjo
Electrical Systems/Wiring
Nov 7, 2014 07:02 AM
meck1
Jun 24, 2003 07:54 PM
CrazyFordMan
Dec 18, 2002 06:52 PM
