trans cooler questions
Old Dec 26, 2018 | 01:43 PM
palacios289's Avatar
palacios289
good morning. I am going to change my stock trans cooler for a 6.0 trans cooler. Since my Ex is a 2000 I don't have the oil to water cooler. I wanted to add an inline magnefine cooler. If I'm facing the front of the truck, which line coming off the cooler is the return line? Driver side line or passenger side line? Thank in advance.
Old Dec 26, 2018 | 05:19 PM
pirate4x4_camo's Avatar
pirate4x4_camo
My .O2 , I would install a new radiator with a Water to Oil cooler like ford did along with the larger air to oil cooler.
also not to be to much of a smartA$$ but the passanger side is the passanger side no matter which way you are facing.
flow
Old Dec 27, 2018 | 09:49 AM
palacios289
Thanks pirate. Question. Can I go with a 6.0 radiator for me ex? I assume the OTW fittings would be 1/2 vs 3/8 of a 6.8 radiator.
Old Dec 27, 2018 | 10:07 AM
wpnaes's Avatar
wpnaes
The how to gives a step by step for the 6.0 cooler. https://drive.google.com/viewerng/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnx3b29 kbnRoaW5nczh8Z3g6MjYzNGRhMGM2YzhiYTliZQ
I dumped my magnifine in favor of the Baldwin. https://www.ford-trucks.com/forums/1...l#post16873514
Don’t confuse with the ps cooler lines which are on the drivers side.
Old Dec 27, 2018 | 11:38 AM
R&T Babich's Avatar
R&T Babich
... Can I go with a 6.0 radiator for me ex? I assume the OTW fittings would be 1/2 vs 3/8 of a 6.8 radiator.
The 5R110 trans cooler uses 1/2" lines.
If you don't want to get a new radiator just yet you could add a B&M Super cooler 70274 with 1/2" fittings along with the 5R110 cooler.
I'm running the OEM radiator trans cooler, the 5R110 cooler and the B&M cooler on our Excur.
From my measurements each one drops tans fluid temps about the same number of degrees.
The OEM radiator trans cooler on our Exped became clogged so I bypassed it and am currently running 2 of the B&M coolers which are working great.
Old Dec 27, 2018 | 02:03 PM
palacios289
R&T, my Ex is a 2000 so I don't have a factory OTW cooler. I was hoping the 6.0 radiator would fit since the fitting would already be 1/2. I guess my question is if the coolant intake and output are on the same location as the 6.8 trans and same hose size.
Old Dec 27, 2018 | 06:46 PM
R&T Babich's Avatar
R&T Babich
Do you have the 7.3L engine?
I think the radiator is the same for the 6.8L and the 7.3L.
The trans determines the size of the cooler lines, not the engine.
The 4R100 trans used behind the 6.8L & 7.3L uses 3/8" lines.
The 5R110 trans used behind the 6.0L has 1/2" lines, and since the chassis is the same the cooler will easily bolt in.
Brass 3/8"x1/2" hose adapters are available for the hose size change.
Be sure to use trans fluid cooler hose.
Old Dec 27, 2018 | 07:26 PM
wpnaes's Avatar
wpnaes
Depending on the need, might be a good time to flush.
https://www.ford-trucks.com/forums/1...l#post12824085
Stinky1
Dec 14, 2012 11:10 AM
wicat3
Sep 9, 2012 01:11 PM
grec-o-face
Jul 14, 2012 01:42 PM
tnwill
Oct 26, 2007 04:35 PM
jinxed
Mar 19, 2006 02:22 PM
