Rearend Lube
Old Dec 25, 2018 | 08:21 AM
kountzecobra's Avatar
kountzecobra
Rearend Lube
A couple of weeks ago I changed the rearend lube in my 2010 F-150 Lariat. I re-filled it with a synthetic 75W-90 lube. The other day I found that I should have used 75W-140. Should I change it out to the correct stuff, or just let it go?
Old Dec 25, 2018 | 08:23 AM
seville009's Avatar
seville009
Should change it; always best to use the correct one
Old Dec 25, 2018 | 08:53 AM
steve(ill)'s Avatar
steve(ill)
the second number is the viscosity of the oil when it is HOT outside, or your pulling a trailer and working the rear end harder. If you were in Canada, it might not make any difference... Since your in Texas, I think the THICKER lube would be better in the long run. Not an immediate concern today.
pepito113
2004 - 2008 F150
Aug 24, 2013 05:25 AM
m.i.nutz
Apr 9, 2009 03:14 PM
Bobby82490
1997 - 2003 F150
Aug 5, 2007 10:18 AM
preppypyro
1997 - 2003 F150
16
Feb 8, 2006 11:58 PM
rwsam
1978 - 1996 Big Bronco
Jun 13, 2002 02:13 PM
