Sponsored by: Auxito
85w140 oil
Old Aug 3, 2007 | 06:22 AM
Bobby82490's Avatar
Bobby82490
85w140 oil
Advanced Auto has some sort of deal now for valvoline 85w140 for .95 cents a quart. Do you guys think that it will be alright to use, i would think that new oil would be better than old oil, even tho your supposed to use 75w140 syn. And with it being so cheap i can get alot of extras so i can change it a couple more times. For the price of the cheapest 75w140 i can get like at least 6 quarts.
I talked to the Advanced manager at the store and he said if i brought a printout of it, then i could get it for .95 cents.
Part Number- 825
Old Aug 3, 2007 | 12:13 PM
grafekie's Avatar
grafekie
I thought my engine used 10w40... or was that 5w40?
Old Aug 3, 2007 | 12:44 PM
galaxie641's Avatar
galaxie641
He is talking about rear diff fluid. I stick with the 75w140 because thats what Ford recommends I assume there is a reason for it
Old Aug 3, 2007 | 05:15 PM
steve(ill)'s Avatar
steve(ill)
i dont think the difference between 75w and 85w is much. the DIFFERENCE is the synthetic. some of these rear ends get hot. i have seen some with the paint burnt off the pumpkin. most have the LS rear end. clearances inside are TIGHT compared to 20 years ago. all that adds up to "you need synthetic". i dont use synthetic in the motor or transmission, dont think its necessary. i do use it in the rear end. i think it is a very good idea. not that it MIGHT be olk. to use generic, but guarantee the synthetic will work. 75w 140 is spec 75 w90 is o.k.--- as long as everything is synthetic. you can use the standard in the front end if you want, but 85w 140 is too thick for that.----- they are giving it away for a reason!
Old Aug 3, 2007 | 05:26 PM
grafekie's Avatar
grafekie
Ah, I figured as much... I just had my rear end done and they used only two quarts. Yes, it'll save some money, but it will also burn up your gears. Stick to what they suggest
Old Aug 4, 2007 | 11:56 AM
Bobby82490's Avatar
Bobby82490
alright, i guess ill just use the 75w140, wheres the cheapest you guys have seen it?
Old Aug 4, 2007 | 03:53 PM
grafekie's Avatar
grafekie
My mechanic charged me $17/qt for the "cheap" synthetic he used on my truck.
Old Aug 5, 2007 | 06:57 AM
Bobby82490's Avatar
Bobby82490
yeah the only stuff ive seen is like $16 for mobil 1, but i remember someone on here saying that they got it for like $7 from somewhere online.
Old Aug 5, 2007 | 07:25 AM
Bobby82490's Avatar
Bobby82490
Summit has Redline syn for $9/qt, so im gonna get that. Now how many quarts does the 9.75 axle take? Last time i changed it i think i put in like almost 3 quarts.
Old Aug 5, 2007 | 10:18 AM
galaxie641's Avatar
galaxie641
Yeah it takes a hair under 3.
imlowr2
Oil & Lubrication
Jan 21, 2021 05:29 AM
THEDON117
Mar 11, 2009 12:00 PM
78fordranger
Feb 21, 2008 07:06 PM
Saguaro_7.3
Oct 8, 2005 02:47 PM
rangedog
Oil & Lubrication
38
Jan 31, 2004 04:49 PM
