You're more persistent than I am, and that is saying something, lol. The process really seems skewed towards towing companies only. However with title in hand, it should be worth quite a bit in this area.
When I bought my wife's 2WD 65 in early 2107, they were going for anywhere from $2-4K for a solid running truck, depending on condition with project condition asking a bit less. We ended up going to Seattle to get one because it was only $1000. A quick CL search shows prices have dropped a little, but that is still pretty close. That said, 4x4s are usually more expensive and this one seems to be factory if the frame VIN matches what you posted earlier. Based of the pictures so far, I would guess you should be starting at least in the $3-4K range IMO unless there is major issues with the interior or rust. Those 4x4 front fenders alone are worth some pretty good money and appear to be pretty solid. It looks like the passenger side has one small, fixable rust through spot. The hood seems to solid as well, which is pretty rare in this area.
