1965 F500 Information Requested
Old Aug 1, 2013 | 11:39 AM
94Sport5sp's Avatar
94Sport5sp
Hi:
I am looking at 1965 F500 ford grain truck and would need to tow it if I acquire it. I would like to know the approximate curb weight for this type of truck. Any ideas? Vin information I have is F50CC581954 with a 156" wheel base, 15000 GVW, Body 481, and Transmission N. If it matters the rear is dual wheel (900 x 20) with single speed differential.
Thanks
Old Aug 1, 2013 | 09:00 PM
shillinghillf600's Avatar
shillinghillf600
F600 weight
I would guess your F500 would weigh 8000 to 9000 lbs my F600 with 14 ft grainbed weighs 8800 lbs. Hope you can aquire that F500 I would love to find one to go with my F600 and F350. We would like to see some pics when you get her home.
Old Aug 4, 2013 | 08:42 AM
94Sport5sp's Avatar
94Sport5sp
Hi shillinghillf600:
That is close to my guess so I will assume 9000 lbs maximum. The box on this unit is shorter at 11 ft so that will lower the weight a bit. I will not be able to see the truck for a while as there is to much happening for me right now.
Thanks for your thoughts
Old Aug 5, 2013 | 01:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN information I have is: F50CC581954 / From the Warranty Plate: 156" wheel base, Body 481, Transmission N, 15000 GVW
F50 = F500.
C = 330 2V Medium Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
581954 = 1965, assembled October 1964.
Sequence of codes as listed on Warranty Plate
156" Wheelbase.
COLOR code omitted.
MODEL code omitted.
BODY 481: 4 = Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
TRANS N: New Process 435 4 Speed Manual Transmission.
AXLE code omitted.
MAX GVW LBS: 15000 = 15,000 lbs. Gross Vehicle Weight Rating.
CERT NET HP = Omitted.
RPM = Omitted.
DSO code = omitted.
Old Aug 5, 2013 | 09:27 PM
94Sport5sp's Avatar
94Sport5sp
Hi Bill:
Thanks for the added information.
HAMS64
Aug 15, 2019 12:12 PM
Dave Squires
May 9, 2019 08:00 AM
Fjcaldwell
Jun 26, 2017 11:32 PM
Sarge01
Oct 2, 2015 09:24 PM
stillwater ford
Large Truck
Jul 24, 2015 04:01 PM
