Scan tool recommendations
Any recommendations on a good scan tool? I see on Amazon they have some for under $100. Also this one looks good.
I would be wary of any tool that misspelled "setup" and "system" on the tool image.
Depending on what you want to do with it, I would try Forscan for free and Torque Pro for $5. Connect Forscan to a Windows computer and Torque to an Android device with a USB to OBD2 cable or a Bluetooth OBD2 dongle. |
Timely topic as I'm in the midst of moving to something a bit more dealer-level diagnostic tool than my current Actron CP9580. That tool has been spectacular for my use but I've flirted with buying the AutoEnginuty kit and will be implementing the FORScan software in the near future.
The Actron version can be had for less than $200 new, the "outdated" model CP9690 (kit) and CP9695 (scanner only) Of course FORScan and Torque are free or cheap enough to use as a first time venture into owning some sort of diagnostic scanning tool. I'm with Sam I Am though----buying something from an obvious "off shore" seller could be 100 times more frustrating that P0171 Lean Bank 1! :) If you read through the questions already asked by others you'll see this might not be the best entry-level scanning tool to consider. Best of luck in the hunt! |
I was literally about to post the same question. Im going with the Blue something recommended by chrisFix. I’ll let you all know what I think after using it a few times. |
My SCT X4 tuner is my current scan tool! }>
Originally Posted by maticuno
(Post 18379430)
Will it work like that? : can I plug it into any of my vehicles to check codes / misfires? |
Originally Posted by Im50fast
(Post 18379811)
i have one too. But it’s programmed for one vehicle but I have multiple. Will it work like that? : can I plug it into any of my vehicles to check codes / misfires? |
I've used my Truck's 5 Star tuner to check / reset codes on many vehicles. It's a decent scanner.
Originally Posted by Beechkid
(Post 18382704)
Thanks BeechKid for the advice! :-X22 |
I have the C-Reader 8001 model from that brand. It works quite well and is what I used to finally diagnose a bad PCM on my F-250 before I had purchased the tuner.
(Post 18383310)
While we're on this topic anyone here using FORScan? I'm about to begin using that, bought what's supposed to be the ultimate ELM327 interface along with a Dell Lattitude laptop newly loaded with Win10. Just interested if its as great as I've read so far. |
(Post 18382704)
IMHO...…….
https://www.amazon.com/dp/B00EN7JOQC...v_ov_lig_dp_it https://www.amazon.com/dp/B00652G4TS...v_ov_lig_dp_it |
IMHO, the bluedriver but only for the reason that if you don't have access (including online which is available through a variety of sources including Helms for as little as $10 for 1 vehicle) to the oem service manual...the description says it will also reference "Free vehicle-specific Repair Reports drawn from a database of over 6.6 million fixes verified by certified auto mechanics"...… otherwise I would go with the other unit.
Ford under 15.00 I would use the Torque Pro app and a ELM327, for 70.00 get a bluetooth adapter and uses forscan which is almost identical to ford IDS. All the readers above are way over priced.
