EOT wiring
Old Jan 30, 2019 | 05:28 AM
  #31
Yahiko's Avatar
Yahiko
You might be able to get away with it if there is nothing else of that wire.
Then just set it up as a temp test and see what happens.
What wire are you thinking about? The return signal wire should not really be an issue.
The Vref side could be if it is feeding other sensors on that leg. The work around for that
would be to make a tap so that you can run one wire to the sensor and the rest still get
power for the other sensors.
Old Feb 6, 2019 | 02:56 AM
  #32
Cameron Papineau's Avatar
Cameron Papineau
I seem to be having similar issues w/ my eot sensor coming through my obd2 unit... sometimes get a reading other times nothing ... no reading at all, I’ve read the whole thread looking forward to any outcomes to help me through. Thanks guys
Old Feb 6, 2019 | 08:23 PM
  #33
Headviking's Avatar
Headviking
Yours might be something else. Because I am getting readings albeit not what it should but always a reading.
Its too cold here in Ontario to do anything under the hood outside. So I'll what for some warmer temps.
Old Feb 6, 2019 | 09:04 PM
  #34
Cameron Papineau
Ya, a ford mechanic said it was not uncommon to have a bad sensor but I’ve also read a bit about wire shaffing being common... my sensor decided to start working again, for how long who knows.
Old Feb 8, 2019 | 08:56 PM
  #35
Headviking's Avatar
Headviking
Before I try to replace the PCM. I think ill just run two test wires from the EOT sensor to the PCM instead first.
golfgooroo
6.7L Power Stroke Diesel
Sep 25, 2022 08:00 PM
Renegade3064
Mar 7, 2022 02:25 AM
RIDETHE
6.4L Power Stroke Diesel
Dec 1, 2011 07:58 PM
KRMusher
Electrical Systems/Wiring
May 6, 2011 05:30 PM
robjs111
1997 - 2003 F150
Nov 29, 2009 04:32 PM
