Ok sorry in advance if this has been asked but have not found the answer. My high beams do not work. With lights on the low beams work fine, flip to high and lows stay on but no highs. The high beam indicator on the dash lights. When the lights are off the flash to pass work. I changed the fuse for the high beam and it is ok. Is there another fuse or relay to try? Any other thoughts? Thank you
Is the truck equipped with either autolamps and/or DRLs? You cannot expect to get solid technical assistance without full identification of what is under discussion. Details matter.
This is an illogical set of symptoms for a conventional (basic system). The high-beam indicator in the cluster is in parallel with the high-beams well downstream of the MFS. It would be impossible for the FTP function to work correctly but to then have a high-beam indicator ON with high-beams off.
Recheck your configuration and symptoms and restate them, if necessary.
