Camper Package Question...
Old May 23, 2019 | 02:54 PM
95snake's Avatar
95snake
I have a 2019 F250 6.7 Crew Cab that I pull a Grand Design 312BHTS with a max weight of 11,000. My payload is 2,980. Take off 1,000 for hitch weight, me and family, another 700lbs, so now I'm at 1,280lbs left for cargo or what ever. I didn't get the optional Ultimate Tow Package so I am limited to only 1,500lbs hitch weight, but I never planned on getting anything other than a Travel Trailer. My truck also has the Snow Plow Prep package. You should be fine, but check your stickers!
Old May 23, 2019 | 04:59 PM
crewzer's Avatar
crewzer
Question
Can you post a picture of your truck’s Tire and Loading Information label?
Thanks,
Jim / crewzer
Old May 23, 2019 | 06:06 PM
BULLSEYEGUY's Avatar
BULLSEYEGUY
Trailering
I don't know if this helps....but...
I don't know if this helps, but .... I went out and took a picture of my door sticker. I have a '19 Lariat super crew F-250 gasser with the camper/snowplow package. I have the short bed though.
Good luck!
Old May 23, 2019 | 06:55 PM
crewzer's Avatar
crewzer
Here’s an example of the Tire and Loading Information label; it’s on the driver side B pillar:
HTH,
Jim / crewzer
Old May 23, 2019 | 09:08 PM
BULLSEYEGUY
Trailering
Tire Load Rating sticker
I'm a dumba$$ I thought you were talking to me.
Yep.
Old May 23, 2019 | 09:10 PM
BULLSEYEGUY
Trailering
The OP was talking about tire size too. You may notice that I have the 20" rims.
Old May 24, 2019 | 10:47 AM
95snake's Avatar
95snake
Unhappy
Thanks,
Jim / crewzer
Jim, I'll post one when I get a chance, but I will say this. After posting this yesterday I look at the sticker again on my way home and I was wrong. It's like 2,180, NOT 2,980! So, I should only have about 480lbs for cargo. I'm heading out today with the camper, so I'm going to stop at a CAT Scale and weigh it. We'll be fully loaded, so it should be an accurate reading. Sorry again about the misinformation.
Old May 25, 2019 | 06:09 AM
crewzer's Avatar
crewzer
Thanks for the clarification!
Safe travels,
Jim / crewzer
Old May 25, 2019 | 10:10 PM
wrvond's Avatar
wrvond
Originally Posted by CathedralCub
The extra sway control of the camper package will help with sway control of the trailer if you have a 5th-wheel or a bumper-pull with a weight-distributing hitch. Higher-rate springs front and rear will help as well, though not as much as getting an F350. If I were doing it, I'd get an F350 for the numbers (that seem to be minimums) that you are talking about.
You are talking about two different kinds of “sway”. The first is more accurately called body roll and is mitigated by the installation of a sway bar or anti sway bar (depending on who you talk to). The second is camper sway, caused by improper loading of a trailer. Fifth wheels, while still susceptible to sway, are much less susceptible than travel trailers. Since the hitches for either type of trailer are able to pivot, body roll of the truck is not going to affect whether or not a trailer is likely to sway.
reluctantfiver
Aug 7, 2024 08:38 AM
Onefortheroad
Jun 27, 2016 02:33 PM
seldomseensmith
Jan 4, 2009 05:20 PM
dads34
Nov 13, 2008 08:48 PM
timcpa
Dec 6, 2005 08:20 PM
