new SD starter problems
Old Dec 19, 2018 | 07:40 PM
mcali2's Avatar
mcali2
I decided to start a new thread because it may pull in more people. I have has 2 new SD started from Napa put in my truck. both will not disengage the flywheel. bent housing maybe?
Old Dec 19, 2018 | 09:08 PM
z31freakify's Avatar
z31freakify
You got one for an auto right?
Old Dec 19, 2018 | 10:11 PM
mcali2's Avatar
mcali2
Yes it was.
Old Dec 20, 2018 | 06:07 AM
427 fordman's Avatar
427 fordman
If the old starter was disengaging and the napa ones aren't, I'd move away from the napa ones and try a different one first.
Old Dec 20, 2018 | 07:58 AM
knottyrope's Avatar
knottyrope
Was the starter still cranking while it was engaged?
I ask because I had issues with the fender solenoid not releasing and thinking it was the starter.
Once I opened up the solenoid, I found the copper lug bolts inside had twisted from tightening the battery terms too tight.
Old Dec 20, 2018 | 09:17 AM
mcali2's Avatar
mcali2
both starters were tested while not bolted down to verify the truck eletrical. The starters were not power up when stuck I
guess. Just not returning. The bolt holes on the starter are larger than the bolts. Adjusting was done to see it it would align up but did not work. The stock starter works fine. They used 2 diferent brand from napa. They are going to order a denso? And see. Ifnthat fails I guess I will not upgrade.
Old Dec 20, 2018 | 10:40 AM
fordpride's Avatar
fordpride
Always go denso or Mitsubishi
Old Dec 20, 2018 | 02:09 PM
mcali2's Avatar
mcali2
both starters were new denso per the parts rep from the shop.
Old Dec 20, 2018 | 05:40 PM
fordpride's Avatar
fordpride
Napa sells denso Wilson electrical not nippon denso
Old Dec 21, 2018 | 08:51 AM
Bob_T's Avatar
Bob_T
Anyone know what the differences between the auto and manual trans starters are supposed to be? When I swapped in a ZF6 I kept the auto starter and it works perfectly. I know there is a big difference with auto and manual spacer plate thickness between the motor and the trans, but the manual trans flywheel ring gear still ended up being in the same location as the auto ring gear.
mcali, if you put your original starter and a new one side by side can you see any difference in the drive mechanism dimensions? When I installed my SD starter I don't recall any significant slop in the two bolt holes, there wasn't room for any adjustment of the starter location, it just bolted up. Hope you get it figured out, this is puzzling. I remember reading other threads about starters not engaging right and I think it turned out to be the wrong starter.
Old Dec 22, 2018 | 09:09 PM
mcali2's Avatar
mcali2
The shop said they were identical except for the slop. The Part guy said he sells this starter to many people who are doing the OBS conversion. I guess if it's not broke, don't fix it.
Dr. Johnson
Oct 21, 2018 07:19 PM
UltraBB
Modular V8 (4.6L, 5.4L)
Sep 9, 2018 12:17 AM
96F150HuntingTruck
Apr 21, 2011 10:37 PM
Greenlawnracing
Jan 2, 2009 02:53 PM
emby
Feb 18, 2005 05:55 AM
