Rpms fluctuating
Old Dec 20, 2018 | 07:37 AM
MD_7.three's Avatar
MD_7.three
Originally Posted by mueckster
Check for codes first. Your description points to a possible ICP problem. You can try unplugging the ICP sensor and let it go into default. If you have faulty sensor, it should smooth out. If this doesn't help, it could also be a sticking IPR valve. Both can be monitored with ForScan and eliminate them as the trouble. You would also be able to monitor TPS.
For ICP/IPR issues though...would they just "disappear" in cruise?
Old Dec 20, 2018 | 11:11 AM
Cole Eakle's Avatar
Cole Eakle
replaced the ICP about 2 months ago when it first started happening.
Jocelyn Woodason
Mar 19, 2017 09:21 PM
DMucci
Large Truck
Dec 3, 2016 03:25 PM
lawdawg79
Dec 10, 2015 02:35 PM
Suedeuno
2004 - 2008 F150
Mar 6, 2012 10:22 PM
msmith53
Jul 3, 2009 10:57 AM
