Gas pedal issue
Old Mar 19, 2017 | 02:31 PM
Jocelyn Woodason's Avatar
Jocelyn Woodason
Gas pedal issue
Help! 1996 f350 7.3 5speed 156k
So started when it was cold 2 days ago let it idle and warm up pulled onto the road and it immediately acted as tho it had no gas pedal. pump it a few times doesn't fix it, sounds like it wants to stall but doesnt, it eventually comes back. then happened again the next day after i drove for 1hour then went away now it's happening a lot more. It doesnt die and it can rev really slow up to 1200rpm while its going or if it does it on the highway it will drop my speed to 45mph then go away I can speed back up...
TPS has been ruled out. Put a new fuel filter on. I cleaned the ivs and held it in with a screw driver while pushing pedal that didn't let it Rev, I'm assuming that would mean it is working. I checked oil etc all checks out ok. Only other issues I've had with it is very hard to start when cold haven't had a chance to test glow plugs yet.
Old Mar 19, 2017 | 09:21 PM
oldbird1965's Avatar
oldbird1965
There is a test procedure some where for testing the pedal.
kurt5153
29
Jul 21, 2010 10:16 PM
hoodjason
Jul 14, 2009 01:47 PM
Bertelrud
Jun 7, 2009 02:25 PM
jamesmcowan
Nov 17, 2007 11:23 AM
Kelsokell
30
Mar 17, 2006 11:24 AM
