1990 F150 acceleration issues
41r - your engine could be running lean, or the O2 sensor is no longer connected, O2 sensor has failed, O2 sensor heater has failed (check fuse #5).
You need to troubleshoot this code 41, or install a new O2 sensor.
I agree that the book assumes a cold-start up. But if the engine sits not running for just 5 minutes, the O2 Sensors without a heater will be cooled off & potentially creating false fault codes. If one leaves the engine running up to the point that they start testing, then no issues. Typically, someone starts up the engine from cold, lets it idle to warm-up and starts the test KOEO Self-Test. Now, the KOEO doesn’t test the O2. Then the engine gets turned off, everyone wanders into the garage to sort out what the codes mean, drink a beer, smoke some weed, then 15-? minutes later the engine is started, left to warm up, no 2K run-up, KOER is performed. So, I want to emphasize the 2K run-up, especially for the non O2 heater models. No Fords will be damaged performing multiple 2K run-ups, maybe chevy’s.
"How would you list an RPM level to reach?" I don’t think I can define this in RPM.
“You are supposed to mash the pedal to the floor and immediately release it?”
Yes, and the book states this, but when I have looked over new troubleshooters’ shoulders, they don’t take it to the floor. So, I am going to modify my note to emphasize going all the way to the floor vice what I have written.
“The tachometer, if you have one, would most likely lag behind the actual rpms anyway.”
Agree.
I might not be correct in saying that the computer is looking for the idle to WOT and back in the test but you are trying to induce a potential pre-detonation condition to test the knock sensor.”
I believe this is to test the voltage range and dead spots in the TPS.
“I would assume that it is looking at the other sensors for changes during that part of the dynamic test but I do not know that for certain.”
I assume the MAP is sensing the change of vacuum, MAF- a change in flow and TPS voltage range. Maybe the A/C shut-off relay during full throttle. All within specified parameters.
My intent is for the 1st time testers/posters, to avoid the 25 & 77 codes that they inevitably get from a sloppy Goose Test, and other issues I have observed. What I posted in post #19 has helped guide beginners, and made it easier to understand what they attempt to provide. I will combine these eventually when I get this right. Thanks for your input.
Code #41 is a good one to get cleared up.
Are you familiar with the SPOUT Connector related to your timing adjustment?
Or where it would plug in...
The 6 is expected if you've got the 4.9l. The very first number returned is the number of cylinders. If it is the 4.9, make sure the clutch is depressed during these tests.
12: Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low). I assume you've already checked the IACV's connections for cracks or corrosion? If not, do that. You might also want to pull it and check for excessive fouling. Don't forget to get a new gasket!
18: SPOUT circuit open. Check base timing & advance function: Diagnostic Sub-RoutinesDSR-3.0 CHECK BASE TIMING
If engine is now a NO START (will not "Fire" at all), reconnect SPOUT connector and go to Section 8A.
- Key off.
- Transmission in PARK or NEUTRAL.
- Turn off electrical loads (A/C, heater, etc.).
- Disconnect the in-line SPOUT connector.
- Start engine (do not use a remote starter, only use the ignition key to start engine).
- Check base timing. Refer to the Ignition/Engine Group in the Service Manual for specific instructions. (For 2.3L Dual Plug, use exhaust side plug. If timing light does not light, go to Diagnostic Sub-Routine 5.0.)
ADJUST as necessary and RERUN Quick Test. If unable to adjust to specification, refer to the Ignition/Engine Group in the Service Manual to check proper distributor orientation, timing chain/belt, etc.
For Electronic Ignition (EI) applications:
Base timing is not adjustable. Refer to the Ignition/Engine Group in the Service Manual for possible causes of incorrect base timing (timing chain/belt, incorrect CMP/Synchronizer sensor orientation, etc.).
- In-line SPOUT connector disconnected.
- Start engine and let idle.
- Reconnect the in-line SPOUT connector.
If ER DTC 213/18 is present:
Disregard any other codes. Refer to the EEC-IV DTC Charts for proper pinpoint test step direction for the DTC 213/18.
If ER DTC 213/18 is NOT present:
Continue as directed in Diagnostic Sub-Routine 5.0.
41r: Oxygen sensor signal, System lean. Dunno about this one. Check the O2 sensor wiring for cracks. While you're down there, make sure the wiring is clear of the exhaust header. Zip-tie it out of the way if needed (PO of my truck had it resting on the header!). If you keep getting it, test the O2 sensor for voltage and resistance.
