Install TBC for 2016 Expedition EL
I just purchased a 2017 26' travel trailer. But there is no Electronic Break controller module installed, in my 2017 Ford Expedition and at the hitch there is only a 4 pin oblong connector. The travel trailer has a round 7pin connector. I have been going back and forth with local FORD parts department, one says just need controller and a 4 pin to 7 PIN round connector adapter . Another ford dealership parts dept says I need the controller, WIRE harness and round 7 PIN RECEPTACLE INSTALLED. ANY NONE CAN TELL THE THEY WAY TO GO?
TBC Trailer Brake Controller
That also means your hitch is the light duty hitch. You better verify what the rating is before you tow. The light duty hitch was a 5k. Also means you do not have the auxiliary transmission cooler either.
kwisniski
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-18-2018 08:04 AM
AK 440
1999 to 2016 Super Duty
08-22-2010 02:38 PM
johnEboy
04-20-2008 12:34 PM
