Install TBC for 2016 Expedition EL
Old 12-18-2018, 08:02 AM
kwisniski's Avatar
kwisniski
kwisniski is offline
I just purchased a 2017 26' travel trailer. But there is no Electronic Break controller module installed, in my 2017 Ford Expedition and at the hitch there is only a 4 pin oblong connector. The travel trailer has a round 7pin connector. I have been going back and forth with local FORD parts department, one says just need controller and a 4 pin to 7 PIN round connector adapter . Another ford dealership parts dept says I need the controller, WIRE harness and round 7 PIN RECEPTACLE INSTALLED. ANY NONE CAN TELL THE THEY WAY TO GO?
TBC Trailer Brake Controller
Old 12-20-2018, 11:34 AM
senix's Avatar
senix
senix is offline
Received 1,429 Likes on 1,022 Posts
you need the harness that will plug into the existing harness. IT will come with the proper 7 pin. Using an adapter would result in a wiring mess with a TBC.
Get the TBC, plug it in and then have the service department activate using IDS.
Old 12-20-2018, 01:07 PM
kwisniski's Avatar
kwisniski
Hey thanks
They did install a harness and the 7pin plug and module, but they zip tied the round connector to the car.. on the other side of the 4 pin connector -- shouldn't thy be on the same time?
Old 12-20-2018, 01:09 PM
senix's Avatar
senix
senix is offline
your hitch probably was not made to accept a 7 pin and a 4 pin connector. Search the internet and you may find one. etrailer.com is a good source to start at.
Old 12-20-2018, 01:14 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
That also means your hitch is the light duty hitch. You better verify what the rating is before you tow. The light duty hitch was a 5k. Also means you do not have the auxiliary transmission cooler either.
kwisniski
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-18-2018 08:04 AM
AK 440
1999 to 2016 Super Duty
08-22-2010 02:38 PM
johnEboy
04-20-2008 12:34 PM
kiosk
1997-2006 Expedition & Navigator
05-07-2005 09:25 PM
FordTE
Electrical Systems/Wiring
08-20-2003 02:59 PM
Quick Reply: Install TBC for 2016 Expedition EL
