Engine knock
Old Dec 17, 2018 | 08:07 PM
J ballan's Avatar
J ballan
Engine knock
Hello everybody, today my 2013 F550 started making a pretty good knocking/tapping sound coming from the top end of the engine drivers side. It was bad enough that I shut it down and got it towed home. Talked to my local mechanic and he told me of similar trucks doing the same thing. I called my local dealership and talked to them. They said there is a good chance it’s a fuel knock and not to worry. So I started it up and the knock was gone. Came back a few miles later once it was back up to temp and I finished my day off with it sounding about the same and not getting worse. They also said if it was a rod knock it would get bad fast. They said to bring it in so he could reset the computer and do a couple other things. Anybody seen anything like this before? I was pretty worried that it was a rod knock. Thanks
Old Dec 17, 2018 | 09:40 PM
FishOnOne's Avatar
FishOnOne
I've read that a defective injector can make a knocking noise.
Old Dec 18, 2018 | 12:46 AM
kper05's Avatar
kper05
Check for DTCs. When my #5 fuel injector started failing, it didn't show a CEL at first but the code was there. Mine didn't make a knocking noise though.
Old Dec 18, 2018 | 05:14 AM
senix's Avatar
senix
run some injector cleaner and see if that helps. Make sure the cleaner is compatible with diesels.
Old Dec 18, 2018 | 06:46 AM
J ballan's Avatar
J ballan
Thanks I will check for codes today.
J ballan's Avatar
J ballan
Any brand in particular that I should try? Thanks
Old Dec 18, 2018 | 12:19 PM
J ballan's Avatar
J ballan
Added injector cleaner and within 2 miles the knock was gone and so far hasn’t come back. Fingers crossed. Thanks for the help. I’m assuming I’ll need a new injector soon but I’ll see how long this lasts.
Old Dec 18, 2018 | 03:41 PM
senix's Avatar
senix
Power Service is the brand I have used. I recently used some from Royal Purple and it seemed fine as well.
Old Dec 18, 2018 | 03:50 PM
J ballan's Avatar
J ballan
This was Enertech Labs inject-r-clean for diesels. Supposed to be good stuff I guess. Sure seems to have helped. Trucks been good all day.
Mountain-man
16
May 26, 2016 12:04 AM
coltac
Apr 8, 2014 11:14 AM
rockster
May 31, 2013 11:00 PM
dmanshane
16
Mar 20, 2012 12:27 AM
skeet
Mar 25, 2005 07:36 PM
