Upgrading brakes ideas?
Old Dec 17, 2018 | 08:07 AM
Angry Tomato's Avatar
Angry Tomato
I've now driven 500 miles on my truck with the 2.5 spring level kit from ready lift and 37's on it. The braking is leaving a lot to be desired and I was wondering if anyone has done anything to upgrade?
I know I have to expect the added wear and load that adding big tires on to a truck does but this is sloppy/spongy at best. I've built plenty of old 4Runner pickups with 35/37s on in the past and I honestly think even their braking was better.
Thanks in advance.
Old Dec 17, 2018 | 08:25 AM
ExtremeDuty's Avatar
ExtremeDuty
Shop around for pricing of course. This is just an example of a quick search. I put these brakes on my '05 2500 HD D/A and even tho' the OEM brakes were fine, these gave it a whole new feel of confidence. Others may chime in with different recommendations.
https://www.realtruck.com/power-stop...018Y743MA.html
Old Dec 17, 2018 | 09:46 AM
whagen's Avatar
whagen
If it feels different than it was before I would bleed the lines again. It shouldn't feel drastically different, just that you need to press slightly harder on the pedal.
Were the flexible lines between frame and axle changed? If so maybe they expand more than stock ones. You can swap them out of higher quality braided lines.
Were any bushing replaced with the lift? That would effect how the truck feels, not so much how the pedal feels. Look at the alignment too.
Old Dec 17, 2018 | 11:23 AM
Angry Tomato
No lines were changed with the lift. Alignment was done and that was adjusted slightly on the toe but was mostly fine/unchanged. No bushings, just the coils and shocks. Id like to just have a little bit more faith in being able to do an emergency stop.
Angry Tomato
Did you change the calipers as well or just the rotors?
Old Dec 17, 2018 | 01:25 PM
Tricon's Avatar
Tricon
I have 35s, not 37s, but I've made 2 panic stops where I really didn't think this 8k lbs beast was going to stop and she did. Took me a while to get used to the brakes over my last truck, but boy do they stop when you need them to.
Old Dec 17, 2018 | 01:39 PM
wicked 2018's Avatar
wicked 2018
Thanks in advance.
My truck seems to brake like stock with my 37's. Can you adjust your shocks to help with any nose dive? Did you put on SS lines? Possibly its the SS lines I put on - then I gave all 4 corners a pressure bleed. Tight confident feeling pedal.
Putting 37's on is not that much more tire or weight than the stock setup - these truck can handle it. Hell, when I tow 10K I can barely feel that behind me. If you are feeling that much of poor braking, I would look at other things possibly. I would start with braided lines - I went with Carli.
Using a bleeder like this makes it a brainless one person, 10 min job:
Amazon Amazon
Old Dec 17, 2018 | 04:42 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Just swapped in Powerstop rotors and pads on all four coners . Like them a lot !!!!!
Old Dec 17, 2018 | 04:45 PM
acadianbob's Avatar
acadianbob
You've got way more rotating, unsprung weight. Of course your braking will be adversely affected.
Old Dec 17, 2018 | 05:06 PM
ExtremeDuty
Rotors & Pads only
Old Dec 17, 2018 | 05:15 PM
ford390gashog's Avatar
ford390gashog
Is your truck a F250 with vacuum assist or a F350 with hydroboost?
Old Dec 17, 2018 | 05:24 PM
Angry Tomato
Thanks for the feedback on them.
Old Dec 17, 2018 | 05:25 PM
Angry Tomato
It's a 250 gasser...
Old Dec 17, 2018 | 05:26 PM
Angry Tomato
Using a bleeder like this makes it a brainless one person, 10 min job: https://www.amazon.com/gp/product/B000Q6SL2W
I have definitely not got a tight confident pedal. In fact, on stopping the truck seems like its creaking at a dead stop to maintain the wheels in a stopped position.
Old Dec 17, 2018 | 07:09 PM
Faceplant409's Avatar
Faceplant409
Talking
I have 35's too and I've had a few panic stops. One in particular I needed to moderate pedal to allow room behind and in front of me and I was amazed at how well the stock pads worked.
I now keep spare skivvies under the seat....
