Upgrading brakes ideas?
Old Dec 17, 2018 | 07:09 PM
Angry Tomato's Avatar
Angry Tomato
Originally Posted by ford390gashog
Is your truck a F250 with vacuum assist or a F350 with hydroboost?
After seeing your post I went out and checked the vacuum line on the front driver and it was dangling in thin air. Reconnected it and instantly the brakes are feeling much better and the acceleration is much better.
Old Dec 17, 2018 | 07:16 PM
BillyE's Avatar
BillyE
That’ll do it!
Old Dec 17, 2018 | 07:18 PM
ExtremeDuty's Avatar
ExtremeDuty
Wow! Good catch.
You owe someone a
Old Dec 17, 2018 | 07:25 PM
Tom N OH's Avatar
Tom N OH
Vacuum line on front driver? Where? At one of the front wheels? At the brake booster on the firewall?
Old Dec 17, 2018 | 07:35 PM
Angry Tomato
There is a small vacuum line that is disconnected when the level kit is installed. It's just behind the drivers wheel pinned to the top of the radius arm. The garage where it was fitted must have forgotten to reconnect it before handing it back over.
I think it's important to point out this has vastly improved the braking for anyone trying to find an answer on this post lift install.
Old Dec 17, 2018 | 08:06 PM
ford390gashog's Avatar
ford390gashog
Glad you found it, I was going to point you in the direction of that hose.
Old Dec 18, 2018 | 09:26 AM
whagen's Avatar
whagen
Surprised there wasn't a check engine light on. Truck will probably run better and get better mileage too now.
Old Dec 18, 2018 | 10:36 AM
BillyE's Avatar
BillyE
I’m impressed you were able to drive 500 miles with no brake assist. You must have a massive right calf now
Old Dec 18, 2018 | 09:12 PM
Angry Tomato
I would have thought that would be the case too but alas, it wasn't.
Yeah, I now look like that guy off the Liberty Mutual adverts.
In truth, the noticeable difference is in braking distance, not intensity.
Old Dec 19, 2018 | 06:20 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The ONLY gas trucks that get hydroboost brakes are DRW's. All SRW gassers have vacuum brakes.
I really miss the hydro brakes that were on my '16 Ram diesel DRW.
jhobbs26
6.4L Power Stroke Diesel
Sep 19, 2019 02:32 AM
gmammakn
May 13, 2015 08:48 AM
KiotiLee
Jul 30, 2008 10:41 PM
sheamus
Feb 24, 2008 01:41 AM
