door locks
Old Dec 17, 2018 | 07:56 AM
crazyjerry's Avatar
crazyjerry
door locks
my doors seem do what they want to, sometime they will lock and half way, i replay the relays under the dash and have the problem, what should i do now?
Old Dec 17, 2018 | 07:12 PM
Franklin2's Avatar
Franklin2
What year truck are you working on? Is this a aftermarket remote lock system?
Old Dec 18, 2018 | 06:20 AM
crazyjerry's Avatar
crazyjerry
1997 expedition factory system. thank you getting back with me on this,
Old Dec 18, 2018 | 07:08 AM
alloro's Avatar
alloro
Have you lubed the linkages and latches yet?
Old Dec 18, 2018 | 02:43 PM
Franklin2's Avatar
Franklin2
Certain year Ford lock actuators are known to be weak. Does it work ok with the engine running, but iffy with it off? The voltage in the system will be a little bit higher with the engine running, and that may be enough to make a weak lock motor work. Like the other poster said, lube may help it also.
Old Jan 31, 2019 | 06:25 PM
crazyjerry's Avatar
crazyjerry
SORRY I DID GET BACK TO YOU BEEN BUSY, I REPLACED ALL THE MOTORS AND EVERYTHING FINE NOW. IT IS A 97 EXPEDITION, EB. THANK YOU.
ltl_jrw
19
Jan 14, 2011 03:07 PM
bigred64
Mar 15, 2010 01:26 AM
Estam
Aug 9, 2009 09:46 AM
jdaniel
Apr 28, 2001 05:47 PM
